Paintball Grenades
Step 9The safety pin
The safety pin
This should have been made befor putting the paint in the grenade but i can figure out how to insert steps. Using plyers make a safety pin out of coat hanger. To brake the coat hanger just bend it back and forth several times fast and it'll break. If you want you can also add a ring to the pin. Once the the grenade is filled and you've put the BB in, keep it sealed and push the safety pin through the hole you made above the collar. After this you should be able to un twist the neck and your finnished.
5 comments
Jul 10, 2007. 1:41 AMtommyskater1 says:
what kind of tubing do you use?
Sep 14, 2009. 5:55 AMswitchpaw says:
between 20 and 16 gauge wire works for the pins.
Sep 14, 2009. 5:54 AMswitchpaw says:
or latex tubing as it is known in hardware stores.
Sep 8, 2007. 3:31 PMdynamite boy says:
you use sergical tubeing
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Prop
