Introduction: Paintbox With Magnetic Pans
I wanted a way to easily switch out the paint in my little box. I use regular paintboxes but sometimes also (altoid) tins. The instructions I found required glueing in the pans permanently or use putty to temporarily stick them in. Putty worked, made the pans easily removable, but a bit messy / sticky. I decided only one thing would give me the flexibility and ease I wanted: MAGNETS
I did find one instructable that used magnetic tape, however, the one I found, wouldn't really stick, and it also added more padding to the pan which made them not fit so well in my regular paintbox (it wouldn't close anymore)
(besides, I like magnets)
I didn't need much to get this to work:
- empty pans
- tubes of paint
- small but strong magnets
- empty altoid tin or paintbox
- water
- knife (optional, for pre-filled pans)
Step 1: Place Magnet in Empty Pan
Place the empty pan in an altoid tin so it won't move around to much. Add magnet to centre bottom.
Step 2: Fill Pan With Paint
Try to get it into the corners as much as possible.
Use a toothpick to swirl the paint around a bit to get air-bubbles out and to get it into the corners.
Step 3: Optional: Use Pre-filled Pans
I have used this paint before, and I have a bad habit of creating wells in the centre. After I wiggled the paint out of the pan with a knife, I placed the magnet in that well and placed the paint - with a bit of water - upside down back in the pan.
Step 4: Leave Paint to Dry
Overnight, or even longer. Some of my paint dried up wonky and still had air-bubbles. I can fix this later on.
Step 5: Little Movie
Pocket Sized Contest
Holiday Gifts Contest
