3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Painting Your Skateboard 101
This little guide will show you how to paint your skateboard with some pro results. I documented myself painting a skateboard 3-4 years ago (bad camera), but you can see what's happening to get an idea of what to do. I hope you learn from this, comment if you like it.
Step 1Prep
Prep
Step one is basic prep. First, you wanna remove the trucks/wheels from the board. This is mandatory, because painting these on the board never works out the way you think it would. If you wanna paint your trucks, it's best to remove them from the board. But if you are just painting the board, remove them anyway.
Sand the board (when I took the photos, I did not sand it, so I do not have any photos for this). This will help the paint stick to the board, and if your board is chrome/shiny like mine was, it's a must. You normally use 400 grit sandpaper for this. Sand the paint/design/chrome off, and your good to go.
When your finished, wash the board with some soap/water, or even better, grease/wax remover. This will remove any grease or oil on the board. When the board is clean and dried, move on to step 2.
20 comments
Mar 8, 2012. 12:30 PMrbennett6 says:
Am i able to paint it with art paint, after say i spray it white
or can i use art paint straight onto a blank deck?
Mar 9, 2012. 3:29 PMrbennett6 says:
cheers man
Jun 8, 2011. 4:29 PMmberg says:
Can I use 100 grit because that's all I got
Jun 7, 2011. 8:35 PMmberg says:
(removed by author or community request)
Jun 8, 2011. 3:33 PMmberg says:
Thanks
Jun 7, 2011. 8:38 PMmberg says:
And a another thing. Would my primer color be gray if I want to paint it blue?
Nov 24, 2010. 11:21 PMkid007la says:
DO NOT...i repeat DO NOT paint your skateboard. I know you might get sick of the design or might want something new but don't paint it. The skateboard manufacturers put a special clear coat on top of the paint which gives the board slide. This is necessary for any board, tail, or nose slides. Sanding and painting this will ruin it and give you too much grip.
Nov 25, 2010. 10:26 AMkid007la says:
maybe, but you never know. if you keep practicing there's not telling what you can accomplish
May 16, 2011. 7:39 PMilpug says:
kid007la, Ive painted several boards and come across this problem. the solution is simple. make a coating on the board with surfboard wax. i used SexWax but it would probably work with any kind. just rub the bar on the board, and smothe the coating out with a heat gun. do this several times. just don't let the heat gun damage the paint.
Mar 10, 2010. 7:11 PMcaco caco says:
coooooooooooooooooooooooooooolll
Feb 9, 2010. 10:22 PMbigredlevy says:
you should try wet sanding the clear coats.
get 380 grit wet and dry paper, dip in water, then sand the board lightly, LIGHTLY!!! it gets rid of the 'orange peel' surface finish. the surface will go dull, but don't worry. whatever you do, DON'T go through the clear to the paint underneath, you will have to re-coat it.
go up a few more grit #'s with the wet and dry, then do the same with a piece of fine steel wool.
then use car polish to buff it back to a shine. it will come up awesome.
Feb 6, 2010. 4:33 PMberky93 says:
Step 6:
Wait a week or so until the paint wears off, and put another cool design on it!
Lather, rinse, repeat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CraigSnedeker(My Blog & Portfolio)
Check my blog for my full bio, I'm to lazy to re-type it :)
