This instructable has been removed by the author.
8
comments
Add Comment
-M
Painting a wiimote or any controller with the hardware still inside can be a bad idea, especially if the attachment port (that thing you stick your nunchuck into), is exposed), gets paint into it. The insides can get all gunky and stop working too (it's a 40 dollar controller, so it isn't necessarily a cheap thing to replace).
You can buy a cheapo tri wing screw driver from the internet (we're talking like a dollar each) to easily open up the housing, remove the guts, and spray paint the shell.
With the screwdriver method, all of the guts will be safe, your buttons will remain the same color, you won't have to mess with taping, and you don't have to hang your wiimote, you can lay both the top and bottom pieces of the shell on the ground.
It produces a better end result too, because spraypainting can be more precise, and you get all of the areas (for instance, the crack in the side, which is a pain to spray paint regularly).
I've done this many times with my controllers, and if you are careful, it can be quite useful.
