Pallet/ 55 Gallon Drum Sled
2,929
24
4
Posted in OutsideSnow
Introduction: Pallet/ 55 Gallon Drum Sled
About: I don't know what to put here
This project is made of material that could be commonly found. It is also a simple project the looks nice and makes a nice sled
Step 1: Material
- carpenters square
- exacto knife
- assortment of drills
- paint scraper or spatula
- safety glasses
- 80 and 120 grit sand paper and Palm sander
- 2 c- clamps or vise grip
- wax bar
- wood putty
- 2 zip ties
- saw zaw with metal blade
- circular saw
- power drill
- screws
- bench or saw horses
- nail set
- string
- and 2 u- bolts
-pallet
-6 inch piece of baboon
Step 2: First Step Pallet to Boards
-select pallet
I selected this pallet from my local dump it was originally double in length
- I used the saw zaw and nail set to remove nail from boards
- I then dissembles the pallet so I had 6 boards
- only need the 1x4s and 1x10s you may throw away the 2x4s
Step 3: Second Step Building Base
- resize 1x4s to 20 inches or with or other board
- clamp 1x4s to end of 1x10s
- then locate and predrill holes for screws
- drill holes
- screw holes into to predrilled holes
Step 4: Third Step Filling Cracks
- at this time I filled all the cracks and knots with woods putty
- I also filled the space in between the two 1x10s
Step 5: Four Step Sanding and Waxing
- I sanded and waxed the bottom of the sled to have less friction while sledding
- I when over the boards the boards with 80 grit sand paper and then 180 grit sand paper
- I then went over the boards with canning wax
Step 6: Step Five Plastic Drum Front
I then cut a 20in by 15 in plastic square out of a 55 gallon drum this will turn out to the front of the sled
Step 7: Step Six the Right Angle
- First I screw the plastic sheet to the base of the sled
- I drilled two holes on each side of the 1x4s so u-bolts will fit
- I then drilled two holes Parallel to the u bolts on the plastic sheet and stringed zip ties to attach string to
- I them tied a string from one to another and adjusted it to a angle of my liking
Step 8: Step Seven Painting Optional
- I though a black paint job would look nice on my sled
Step 9: Step Eight Optional Handle
- I used a bamboo chuck off an old fishing pole
- I then drilled though the bamboo and pulled the strong though
- I then tied a string to each string already on the sled
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
4 Comments
I got the baboon off a old baboon fishing pole I bought at a action for a dollar for about 10 7 ft poles great for other projects
I'm going to have to try this out. I'm getting sick of destroying sleds and inner-tubes.
But where would one go about getting a six inch piece of baboon? I'd rather not end up with a restraining order from the local zoo ;)
