Pallet Bench/Shoe Shelf
1,409
54
Posted
Introduction: Pallet Bench/Shoe Shelf
Started with some old pallets.
Break them down and use the planks and the braces
They break easily when being pried apart.
The darker pieces were purchased from the Habitat for Humanity ReStore. Thecabinet door will be the seat of the bench and the mold will be broken down to use as a decorative piece
Step 1: Cut and Sand
Cut the planks to fit as deep as you want your bench to be.
Cut the braces into 6 pieces : 4 legs, 2 Xbraces
Sand everything well. The pallets got pretty banged up from disassembling
Step 2: Dry Fit the Legs/braces/planks
Step 3: Paint Whatever Colour You Like
Step 4: Upholster Cushion
Cut a piece of wood (i used scrap OSB) to fit the size of cushion you want for bench
Cut foam (1/2" in this case) AN EXTRA 1/2" on all 4 sides
Cut fabric to be longer than needed. As you staple fabric to board pull nice and tight, but not too tight. It should feel nice and firm
Staple piping around the end. This will hide any lifting and add to the overall appeal of the cushion.
Attach cushion to bench. I used 1" screws, high quality velcro is another good choice, allows for easier removal (to re-upholster) but may slide.
Step 5: Construct Legs
Construct the legs with planks spaced evenly apart
Put a brace in the middle (being hidden on a plank)
At this point the bench top is just for reference*
Step 6: Attach Bench Top to Legs
Attach bench to legs with screws (i used 2-1/2" screws)
Put them in spots they will be hidden (under cushion and where the trim will go)
Add a brade going across the underside of bench
Screw it to the planks, add nails to the bench (again, where they'll be hidden by cushion)
Step 7: Cut Trim to Wrap Around Corner
Angled cuts and at appropriate lengths
Do not have them go UNDER cushion, just butting up against it
Step 8: Attach Shoe Shelf and Cushion
I suppose this is optional, but my bench is intended to be used at a front entrance, so a shoe shelf was appropriate
Cushion went on last, after paint touch ups to make sure it was kept clean
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    3 Comments
    Yes, very nice. Though, what keeps it from wobbling from side to side?
    In step 6 there is a brace on the under side of the bench. This is butted right up to both ends which stops any wobbling. To a certain degree the shelf itself also helps with lateral support.
    Very nicely designed! It looks great!
