For this step I lined up 5 boards of equal length. You can choose to use more or less boards depending on how big you want your table to be.
Step 1:
This is where you will be making the support struts for your table. Cut a piece of wood into two pieces that are the same length as the width of the table. Then mark where they should go, and nail the supports in from the top, so that they hang below the table when it is finished. From here, I chose to put small shelves on the bottom of the struts. This will also give the table some storage room and make it more appealing to look at.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
