Pallet House to Save the World... or a garden shed.
My middle school class designed and built a basic prototype for a house made of pallets.  The pallets are for the basic wall structure, and other materials can be used as sheathing, the floor, roof, etc.  With a little imagination the builder can fill in the gaps.
One inspiration was Alexander Saunder's op-ed piece in the New York Times about helping victims of a 2005 earthquake in Pakistan.  His piece "Give Them Shelter" suggested buying garden sheds from Sam's Club en mass and dropping them into isolated regions.  It is an interesting idea.
We also used several sites dedicated to a "Tiny House" movement, which we first saw in a local piece "Stuck in Vermont".  Tiny houses are houses about ten-feet by ten-feet and intended to be lived in (windows, loft beds, water and the like).  There are many other sites dedicated to the movement.  This movement, in turn, was inspired by Thoreau and Walden, which we read excerpts from.  Many of these sources stressed simplicity and self-reliance.  They also dovetailed with groups looking to solve the problems of homelessness and the environment.
There are several Instructables that will support this project, but "Pallet Playhouse" is mentioned several times in the article as it has excellent information on deconstructing pallets and using their cannibalized parts in interesting and creative ways.  I suggest you read it during the design phase and revisit it periodically.
Because we embraced the ideas of civic involvement and recycling we put down two simple rules:
First, everything had to be found.  Because of this, we used pallets.  You will see that we used a refrigerator door for the door.  Even our nails were a rusted mass that we found, and much of it was bound with twine.  We speculated the builders could use anything from scrap wood to crushed soda can shingles for siding or the roof.  The user of this design can use their own ideas and the resources available, as more appropriate nails and ties will make your own results much more sturdy.  The aesthetic, though, was renewable and found so that materials could be found at the site for free.
Second, it was designed to be moved.  We hoped that the basic structure could be manufactured at a central site, sent to its permanent site as a shell and finished with local materials.  Therefore, it had to come apart and reassemble easily.  The main conceit is that the pallets are nailed two each into a panel.  Then, all other connections come apart easily.  In this way, the entire frame can be stacked and moved on the back of a truck or pushed (bound) out of a cargo plane.  On site it can then be assembled.
Mainly, though, we wanted to create a simple shed that anyone could build from materials anyone could find.  Adapt to suit your needs and change your own little piece of the world.
Step 1Materials
Materials
For the frame of the structure we used:
Pallets.  We chose them because they are plentiful; indeed, everyone seems to always want to get rid of them.  Still, check with a store manager to be sure (our local food coop gets a deposit for returning theirs).  They should be uniform in size.  Some pallets are treated with a chemical to prevent bugs hitchhiking to foreign lands via international trade, while others are pressure treated.  The Wikipedia article "Pallet" has extensive information about sizes and also how to identify how they were treated.  You will want at least sixteen for the building we made, plus extras to cannibalize for lumber.  The nature of pallets are such that you may find some are not sturdy or "quite right", so spares are worth having about.  Also, if you wish to use pallets for your floor or roof you will need to calculate in those extras, too.
The Instructable "Pallet Playhouse" has excellent information on deconstructing pallets and using their cannibalized parts in interesting and creative ways.
* Three inch nails or screws
* Twine and duct tape
* More pallets
Considerations for finishing the structure:
* Door.  We used a refridgerator door from the dump (free).
* Hinges.
* Windows.
* Sheathing
Again, "Pallet Playhouse" has some interesting ideas about this.
Tools required are:
Hammer
Handsaw
Pry bar
Drill to pre-drill (pallets are made of a hard, hard wood)
40 comments
Apr 6, 2011. 3:23 PMbakermonitor says:
U could try unrolling a oil drum.
Feb 14, 2011. 9:39 AMletstrythat says:
I really like your project.,
What a great way to recycle pallets.
It would be very easy to make a wood shingle roof
out of more pallets if you have a band saw.
Great post!
Jul 12, 2010. 12:37 PMBroberg says:
One idea for siding is to use old newspaper printing plates. They may cost a little bit but the recycling is worth it! With the plates being a bit larger than a flattened can, the build would go much faster. I have always looked at ways to build with pallets and this just gave me a couple ideas. Keep up the good work!
Nov 18, 2010. 10:09 PMCapnKlay says:
My Father and I build a shop on our farm when I was a child. We used salvaged lumber and sheathed it with salvaged roles of tar paper and later newspaper printing plates. It has lasted for almost a half century.
Nov 16, 2010. 8:44 AMKittyF says:
Ooooh, I can see having one for a garden shed, and one for a compost heap, and one for the kids toys, and one for a fort, and one for a Creche, and one for a studio, and, and Then when the yard is full, where will anyone play. LOL
Aug 11, 2010. 8:20 AMLePyro says:
Why not keep the Palettes as they are in order to stuff insulation in between them??
Jun 23, 2010. 11:04 AMwidesheds says:
Hay Nice... Person may take an advantage to prepare a nice plan regarding them shed. So, please keep updates in it. & yes Thanks for sharing this great information with us.
Jun 21, 2010. 5:11 PMJamesTB13 says:
I've always wanted a little club-house/fort type thing. This is perfect! I'll just look behind Rona, use their pallets. I agree with patmac, it's VERY well written. Thank you for putting this up, and great Instructable. Also, to InvaderDig, lol. That's all I can say. P.S., I take it, from you always referring to 'my students', that you're a teacher, KEEP TEACHING THIS KIND OF STUFF, IT'S AWESOME.
Jun 20, 2010. 4:21 PMMCASOTTANA2 says:
Great idea! It can lead to many more creative structures!
Jun 19, 2010. 12:05 PMseamsbysami says:
wow! this is cool ive always wanted an easy way to make a garden shed good job.
Jun 14, 2010. 1:33 PMshooby says:
Great idea. I'd love to see a formal application of this, perhaps combined with another re-purposed material for finish and insulation.
Jun 4, 2010. 8:30 PMbobbypin says:
I can see a lot of potential in these pallets, however, I am very concerned about what chemicals are used on them to treat for weather resistancy and insecticides. I wonder how someone could find out for sure.
Jun 6, 2010. 7:59 PMSpeedmite says:
Nice job but, if you cling wrapped the entire thing, wouldnt there be a risk of suffacation?
Jun 7, 2010. 6:45 PMinspiredjules says:
Thank you so much for this idea! I'm lucky enough to have a roof over my head but I have been searching for weeks for a way to build a cheap, not over the top cubby house for my daughter and I'm stoked that it's easy enough for me to give it a go - I won't have to rely on hubby to walk me through every step, although no doubt once I start it will suddenly be his project! :) Anyway, as I'm new to this site just thought I'd say it's great and I can't wait to have a go. Cheers.
Jun 5, 2010. 11:09 AMkaterlyn says:
CHUCKLE about MIL coming to stay. I love these instructables, thanks for the great thought inducing instructable.
Jun 4, 2010. 6:18 PMblopez says:
For the first three years of my life (1949 to 1952) I lived in a two room house that my father and uncle built over two weekends using wooden orange crates and tar paper. Housing was in short supply just after the war as were building materials. It was heated with a wood stove, water had to be hauled in and an outhouse sat a short walk away. The second room was downright cold in the winter when the fire went out during the night. I'm told I woke in the morning with frost on my diaper.
Jun 3, 2010. 8:51 PMwstarvingteacher says:
 As a variation, one of the local motorcycle dealers had shipping crates to give away.  About 4X10.  I used them for the walls and the frame for an outside shed/shop on my property.  Used salvage metal roofing I picked up from the junkyard for the roof and landscape timbers where the crates would not suffice.
 This is not meant to be oneupmanship.  Just to say that the stuff is durable (same pallet material as here).  It has been up over 10 years without any maint. Probably cost me less than $500 to make about a 20X20 shed.
Jun 3, 2010. 8:37 PMrick.leasure says:
While I was reading this, I thought of what I would do if I didn't have a place to live. Pallets converted into a living space seems like a way to go. Build it in a thicket for protection and to hide it from view. Use found, recyclable materials to weatherproof it.
A friend once took an uninsulated outbuilding and lined the inside with first plastic, then cardboard to make a cozy home for himself.
Jun 3, 2010. 8:20 AMlucek says:
again this is a really good project but as the state round here hands out compost bins for practical nothing there's not much reason for me to go to the trouble for an inferior bin.
http://www.mass.gov/dep/recycle/reduce/images/bothbins.jpg
Jun 3, 2010. 11:35 AMsarujin says:
except that the site is called "instructables" and not "readymadeproductsgivenawayforfree" (which would be a good site)
Jun 3, 2010. 4:53 PMlucek says:
I don't argue the point, I was just commenting that it's moot for me. for people who don't have their taxes go to subsidize compost this is fine (air flow and turning may be a problem).
May 28, 2010. 12:50 AMSASilhouette says:
 Why not just pull the nails and use the individual boards as raw lumber?
May 28, 2010. 7:20 AMjohnpombrio says:
 Heh, It is obvious that you have never tried to remove the nails from a pallet! There are TONS of nails and they are usually clinched over, rusted and deeply embedded. The fastest way is to properly leverage the boards and then jump on the cross joint which, as I found out, is DANGEROUS!
Jun 3, 2010. 11:41 AMsarujin says:
The quickest way to liberate the boards is a reciprocating saw with a metal cut blade.  You can also cut it along the inside edge of the support beam if you don't want to be bothered with removing the last bit of nail and shroten the total length.
You are right.  Not only is it very difficult to pull, you risk cracking the board as they tend to be hardwoods.
Jun 3, 2010. 6:56 AMLucy1365 says:
Some years back, I tried to make a compost bin out of pallets.  But it was one of those projects that didn't get finished.
Where I live, pallets are accessable since many carpet plants are in the area.    They can be used for so many different projects, such as chicken coops, vegetable gardens, dog houses, etc.  Why not put them to good use?
www.basicdogtraining.info
Jun 3, 2010. 11:37 AMsarujin says:
I took 3 pallets and nailed them at the top and put long stakes through the top to keep them upright.  After that they really don't move at all.  You can add a 4th wall to keep it all closed in if you like.
Jun 3, 2010. 8:24 AMpatmac says:
I enjoyed reading your instructable not only for the subject matter, which is amazingly creative, but because it is written so well.  Your use of the language is correct as is your spelling and I can't tell you how satisfing it is to read such a well written article.   Thank you.
May 27, 2010. 9:39 PMBobS says:
Great idea! 3 remarks:
If it is built outdoors it should rest on and be connected to 4+ foundation blocks (buckets filled with concrete) with thread sticking out, so it can widthstand storms.
Be careful for splinters!
Building regulations...vs. hiding in sight
May 28, 2010. 7:54 AMknexfan9182 says:
The best part about this is that pallets are very cheap.
May 27, 2010. 5:58 PMMoonieK says:
Awesome you have inspired me to have a go myself!
May 27, 2010. 5:16 PMmarinermcv says:
 Just have seen Pallet homes in action in Haiti, with blue tarp/ old advertising
banners. Still pretty rough.
May 27, 2010. 12:27 PMChristian28 says:
What is great the pallet house?
May 27, 2010. 10:19 AMTool Using Animal says:
The idea of this, with a sod roof and grape vines on the side, make me all fuzzy warm inside.
May 27, 2010. 9:33 AMCulturespy says:
 Now I can have that rooftop office I've always wanted!
May 27, 2010. 9:29 AMInvaderDig says:
What a great use for pallets. I think I'll build one of these for when my mother in law comes for a stay.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:darlingtom(Tom Darling Writes!)
I like to explore with my hands, but I trouble choosing one thing. I have completely renovated my house, but want to build an electric car, hack computer hardware, build an FM transmitter, make a sto...
more »
