Step 10The Skin
You can use barn board, clap board or plywood. You basically have a balloon structure at this point, and need to sheath it accordingly. Again, in the Instructable "Pallet Playhouse" the author found pallets that were sheathed with particle board, which he was able to use. Once you begin to notice pallets you'll notice they are everywhere and your mind will start to fit their pieces into your house.
We thought that crushed metal cans (soda or gasoline) might be used as shingles for either the walls or roof. This Instructable tells of making a tin wall out of soda cans, and while meant for interiors it will give you ideas (or at least make a nice interior wall). Similarly, plastic battles can be cut and unrolled and used the same way (and their transparency offering sunlight). We even thought mud or plaster (or snow) could work for the walls if the decks of your pallets are close enough together. It is solid enough to act as a frame for stone, either dry or motor. Even a tarp stretched over the frame walls or roof will provide a solid shelter.
If this is for your backyard garden shed, your choices will be more aesthetic.
A solid sheathing like plywood will give your structure more support as racking can be a concern. If you shingle make sure it is solid; reinforce as necessary.
Add Comment
