Introduction: Pallet Snowman
About: Hi my name is David, I like to make things out of Wood, also like to take things apart and fixed them.
In this Instructable, I will show you how to build a pallet Snowman.
You will need:
2 Pallets
Jigsaw
Air Nailer or Hammer
Nails or Screws
A couple of small tree branches
Outdoor Paint ( White and Black)
Paintbrushes
Cardboard ( a piece 2" Wide x 18" Long
Handsaw or Bandsaw
Titebond Outdoor Wood Glue
Step 1: Pallet Assembly
You will need 2 pallets or 1 solid pallet and enough pallet slats to fill in between like shown in the pictures.
With the extra slats, lay them in between the others until they are are filled up. (picture 3)
Then nail those slats to the pallet, only nail the center sections.(picture 4 and 5)
Step 2: Make a Cardboard Gauge
Find a cardboard box and cut a piece 2" wide x 18" long. Put a nail thru it at 1" from the top.
Then measure from that nail down to 5 1/2", 9 1/2" and 15 1/2" . Make a hole in those spots with a nail.
Now we have a gauge to mark the cutouts for the Snowman
Step 3: Snowman Head
Measure form the top of the pallet, 5 1/2" down and make a mark. (Try to stay in the center of the pallet)
Now place the cardboard gauge with the nail at the 1" mark at the 5 1/2" location. Slightly hammer the nail into the pallet as shown in the pictures. (Do not nail to deep, as we will have to pull the nail back out)
Now place your marker in the hole on the gauge at the 5 1/2" mark. Rotate the gauge with the marker touching the pallet, making a complete circle as shown in the pictures.
Note you may have to adjust your gauge according to your slats width
Step 4: Snowman Belly
Measure form the top of the pallet, 18 1/4" down and make a mark. (Try to stay in the center of the pallet)
Now place the cardboard gauge with the nail at the 1" mark at the 18 1/4" location. Slightly hammer the nail into the pallet as shown in the pictures. (Do not nail to deep, as we will have to pull the nail back out)
Now place your marker in the hole on the gauge at the 9 1/2" mark. Rotate the gauge with the marker touching the pallet, making a partial circle as shown in the pictures.
Step 5: Snowman Bottom
Measure form the top of the pallet, 36 3/4" down and make a mark. (Try to stay in the center of the pallet)
Now place the cardboard gauge with the nail at the 1" mark at the 36 3/4" location. Slightly hammer the nail into the pallet as shown in the pictures. (Do not nail to deep, as we will have to pull the nail back out)
Now place your marker in the hole on the gauge at the 15 1/2" mark. Rotate the gauge with the marker touching the pallet, making a partial circle as shown in the pictures.
Step 6: Jigsaw Time
Now take your Jigsaw and cutout the lines that we made.
After all of those marks are cut, flip the pallet over and cut the back slats close as you can to the 2/4's (as shown in the pictures)
Step 7: Paint Snowman
Now it's time to paint the pallet, I used Krylon White Latex Enamel.
Note before painting, slightly go over the pallet with a piece of sandpaper, especially over the jigsaw areas
Step 8: Buttons
I found a old tree branch in the yard about 2" round. Cut 3 pieces roughly 3/4" thick.
Nail those piece's to the belly section of the Snowman. ( I used a air nailer, but you can use regular nails and hammer)
Note you could substitute the branch buttons with something else, I didn't have anything on hand
Step 9: Eyes and Mouth
I found another old tree branch in the yard, about 1" diameter. I cut several pieces about 1/2" thick to use for the eyes and mouth. Attach these with Air Stapler.
It would probably be a good idea to use some outdoor glue underneath each piece before nailing
Note you could substitute the branch eyes and mouth with something else, I didn't have anything on hand
Step 10: Snowman Nose
I used the same 1" diameter tree branch for the nose. I cut a piece about 3" long, drilled a hole with a 1" spade bit as shown about 1/2" deep into the pallet. Put some glue into the hole and insert the piece.
Wipe off excess glue before it dries.
Note you could substitute the branch Nose with something else, I didn't have anything on hand
Step 11: Paint Nose, Eyes, Mouth and Buttons
Now it's time to paint the wood branch pieces that we cut for the Nose, eyes, mouth and buttons
Note you may have to add a second coat of paint
Step 12: Bottom Brace
Now I came up with a idea of cutting a couple of scrap pallet pieces at a angle as shown in the picture. Then attached them with screws to the bottom back side of the pallet as shown in the pictures
Note I use this because I was going to stick it into the ground, You may have to alter the bottom for your needs
Step 13: Enjoy Your Snowman
Now stick your Snowman into the ground and Enjoy. Thanks for checking out my Instructable.
If you liked my Instructable, you should check out my youtube channel, I post a new video every week. Click here for my channel
