We AKA my friend Emma and I Decided were given the task of creating outdoor furniture from a total of 4 wooden pallets. After some many days in the lab and couple brief starbucks runs we decided to do something out of the ordinary and create a pallet swing and designed from the ground up based on a picture we found online. In the next couple of steps we show you a brief step by step run down of how to get to the finished item.
Items you will need.....
jig saw
chop saw
nail remover
hammer
screw gun
4 wooden pallets
sufficient amount of screws
patience
metal chain and u-bolts
carriage bolts and nuts
and finally!! a bearded lanky gouchy engineering teacher who doesnt give you enough time!! (JOKESS!! DONT FAIL ME MR Shultz) but like seriously having this will help get your lazy butt in gear
Step 1: The tear down
the first step to any project using pallets is the actual breakdown of the wooden pallets. for our project we found it more simple to cut the pallets apart using a jig saw, it was quicker and easier and there was less of a chance of split wood vs using a pry bar to pry the wooden pallets apart...... the down side is we lost a lot of longer pieces of usable wood that we could have gotten if we attempted to pry apart the pallets. in the end its what ever you feel most comfortable doing. the photo below is how we deconstructed our pallets
nlejet-morton says: May 11, 2013. 6:22 AM
I love this idea... But you instructions were quite Vague!! Especially for a new builder like myself! I'm exited to try this and have pallets all ready to go but I have to decipher between steps all the small cuts and angles. :(.
Foo_Plinger says: Apr 22, 2013. 4:56 PM
The swing in the picture does not resemble the one they built in the instructions...look at the back, the first one has thin strips of wood, set horizontally, theirs has wider pieces of wood set vertically. The bottom has the same inconsistencies. Why not show us what your swing actually turned out like?
hms1018 says: Jun 26, 2012. 9:20 PM
Sweet!
rwill53 says: May 4, 2012. 12:38 AM
You mentioned using a jig saw in your text, but I didn't see one or read how you used it.
klincecum in reply to rwill53May 11, 2012. 11:20 AM
They meant circular saw.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
