3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pallet Workbench
Pallet Workbench
****** My first instructable. In portuguese and english. ******
BR:
Uma bancada pare servicos gerais constuida com pallets de madeira descartados.
Simples e funcional para quem tem pouco espaco e dinheiro curto.
Mede 1,20 x 0,7 m, com 0,9 m de altura.
Custo total: em torno de R$40,00 (parafusos, verniz, pincel).
ENG:
A simple workbench constructed from disposable wood pallets.
Measures: 1,20 x 0,7 m, 0,9 m height.
Costs: few bucks (screws, some varnish)
Step 1Pallets
Pallets
BR:
Consegui alguns pallets em uma empresa de cargas. Geralmente, os pallets sao descartados e enviados para reciclagem e as empresas nao se importam em doa-los.
Os que consegui sao de madeira boa, porem o acabamento das madeiras inferiores eh bem ruim.
ENG:
I found some pallets on a cargo company. They generally dispose it, so they will don't mind give you some.
The wood on top was nice, but in the bottom it was not so good.
27 comments
Dec 19, 2011. 6:08 PMbugzapper says:
It won't let me download the sketchup file, just comes up with a whole lot of letters in Korean, how can I fix this?
Jul 8, 2011. 10:57 PMsmaster says:
Olá amigo, obrigado por compartilhar as informações!
Abraços!
Apr 9, 2009. 7:33 AMniquattx says:
This method of removing boards is work intensive! GET A HACKSAW AND SAW THE NAILS OFF!
May 6, 2010. 3:50 PMred-king says:
 I would have suggested a crowbar. I don't think it would be very easy if you sawed the nails off.
Jan 15, 2010. 1:59 AMricardo4265 says:
Excelente trabalho. Continue postando.
Dec 7, 2009. 5:14 AMshoppe says:
I love the two wheels on the side of the legs.  I just built a stand for my table saw and I will be using this trick to keep it stable when I'm cutting, but still allow for it to be rolled around.
Dec 5, 2009. 3:59 AMpheenix42 says:
Do they make a hole saw in a small enough diameter to drill around the head of the nail?  If so, that would be the most effective way to disassemble a pallet as the only thing you would have to do after would be to cut off the nail with an angle grinder or some such tool.
I thank you for the instructions, sir..very clear and easy to follow!
Dec 5, 2009. 9:18 AMopanocat5 says:
 In  Portuguese as well!
Obrigado amigo multa Portugues!
Dec 5, 2008. 12:31 PMmikedoth says:
I've always seen a secondary use to pallets yet never had time/space to experiment. I'll keep this in mind when I finally get a house and need a workbench, good job!
May 21, 2009. 6:40 PMDIY-Guy says:
A secondary use for used pallets, even partially broken ones- Pallets make nice large compost bins. A three walled square with the fourth side open works well for dumping wheelbarrow loads of organics onto the compost pile.
Apr 29, 2009. 12:03 PMjagman111 says:
very nice is the wood oak ?
May 12, 2009. 12:07 PMthepelton says:
I have learned how to recognize hardwood pallets. They are probably about a quarter of the pallets made. The wood looks different, has no resin spots on it, and smells different. Ask someone who is more experienced if you are not sure it's hardwood.
May 12, 2009. 12:05 PMthepelton says:
I made a workbench from two identical pallets stood on end, a piece of chipboard sheet, and some two by fours. The chipboard sheet was screwed into the end of the pallets, and the two by fours braced it, resting on the crossbar pieces. For more stability, I bolted it to the wooden pillar in the center of my garage. It worked quite nicely, until I had to take it apart.
Dec 6, 2008. 7:49 AMBam82693 says:
Thats a lot of words for deep nail holes.
Jan 3, 2009. 6:30 PMmynameisjonas says:
don't listen to him. your English was just fine! it's always nice to see instructables in languages other than English.
Mar 8, 2009. 6:07 PMBam82693 says:
i didn't want to sound mean, i just thought that the translation for deep nail holes had a lot of words, and that it was funny. His English is good.
Jan 3, 2009. 6:32 PMmynameisjonas says:
this is a great instructable! a neat way to recycle those old pallets. I need a new workbench & I think that this would be perfect! thank you very much!
Dec 10, 2008. 11:30 AMgrunthos says:
I like the pictures showing the disassembly using the wedge. Nice work!
Dec 6, 2008. 11:24 AMold_code says:
Good job; clean and straight-forward. I've looked at pallets for a while and wondered what sort of things I could turn the wood into. This could be a great start.
Dec 5, 2008. 1:57 PMsnoyes says:
An instructable on how to disassemble a pallet in a timely fashion would be most welcome. Those things don't like to give it up!
Dec 6, 2008. 4:52 AMsr1sws says:
Nice job!
Dec 5, 2008. 8:46 PMsdallesasse says:
Great idea! I work in construction and there seems to be pallets on every job. This would be a great surface for plans etc.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:rcaproni
Part time electronics hardware design engineer, part time maker.
