Introduction: Pallet Table (UPDATE!!)
DON'T GORGET TO VOTE FOR ME IN THE WOOD SECTION!!
collect a pallet with small pieces of wood and with straight legs for the tabel.
Tools/Material i needed:
jig saw
miter saw
rule
pencil
screw
glue
sander
hand planer
screw machine
drill
Step 1: 1. Top Desk
Make layer 1 first.
The outside length is 80 cm.
You can already saw the pieces you need later in the project.
So you can make 12 pieces of 80 cm with an angle of 45.
Step 2: 2. the Legs
The legs you can make whatever length you like.
Each sofa has a different height, so you need to adjust the table to the sofa.
If you have shortened the legs then you should bevel the edges.
After that you can make the legs underneath the first top layer.
Make sure the legs are properly screwed and put glue in between.
Step 3: 3. Second Top Layer
You have the wood already cut for the top layer so it can be put together.
When this is done, it can be glued to the other layer. Clamp this well and screw it together.
Step 4: 4. the Inside of the Toplayer
Now, the inner layer can be made.
There must first be screwed on a slat where the inner part rests. Then you can start on the inside. (be sure to glue everywhere in between. Pallet wood shrinks much.)
Step 5: 5. the Bottom Layer
The wood you cut for the bottom layer, you can now assemble.
Make the layer in the same way as for the top layer.
Saw the corners for the legs.
Screw it all together
(sorry, forgot to take pictures)
Step 6: 6. Stain/varnish/paint
Go to the shop and look for stain/varnish/paint you want.
I chose a clear varnish because I do not want to change the wood color.
Wood Contest
