I do travel many times a year, sometime I went with family, took relatives, friends, to places in US, for days, may be for weeks, even for a month, when I traveling aboard to visit my family once a year.
Previously, I left my Arduino project(s) untouched for the duration of the traveling. And most of the time, after i got back, I had to start the project over, because I was already forgot where it was left off. During the time of traveling when I got some idea for prototyping, I could not do anything since I did not have Arduino stuffs at hand. And I missed working on the project(s) very much while I was traveling.
This time I planned to do something about it! And this was I prepared them for. A Palm Arduino Kit.
The kit contains:
A DIY palm size Arduino compatible board
A mini breadboard (Commercially available)
A DIY 5V Portable Voltage Regulator (Step 6)
A MOD FTDI cable (See my FTDI adapter instructables details here.)
A MOD 2" Long Antistatic IC Container.
2.25" Wide x 3.75" Long x 1" Hinge Plastic Box (Commercially available)
Palm Arduino
Whenever I look at 28-pin DIP ATMega328 IC, I always wonder do I have to use it this way all the time, with the pins hang out beside it body. Could I just straighten it out and do something similar to Freeform Arduino? And don't have to use PCB just like the Freeform Arduino, but make it more portable than Freeform Arduino. The other criteria that I use to design this palm Arduino is that it would be small enough to be with some other components to be fit inside 2.25" Wide x 3.75" Long x 1" Hinge Plastic Box.
So the Palm Arduino is born! And I made it to be only 1.5" wide x 2.5" long x 0.5" thick.
Remove these ads by
Signing UpStep 1: Parts and Tools
And I would like to thank ColorBomb, an Pro Instructables friend, who volunteer to make the schematic in the better format than my had drawn schematic. Thanks for your time and generosity.
Parts
Arduino compatible:
1 no. ATMega328P with Arduino Bootloader
1 no. 3mm Green LED
1 no. 1K Resistor
1 no. 10K Resistor
1 no. 16Khz Resonator
2 nos. 0.1uF Capacitor
1 no. 1x6 Male Header
1 no. 1x14 Female Receptacle
1 no. 1x4 Female Receptacle
1 no. 1x6 Female Receptacle
2 nos. 1.5" wide x 2.5" long, 1/8" thick clear Acrylic sheet
Plastic Standoffs
Some hookup wires
4 nos. 2-56 Round-Head Machine Screws (Radio Shack# 64-3010)
4 nos. 2-56 Steel Machine Hex Nuts (Radio Shack# 64-3017)
Portable 5V Regulator
(See details instructables here)
9V Batterry
9V Battery Holder
Slide switch
78L05 Voltage regulator, package: TO-92
100uF Electrolytic capacitor
10uF Electrolytic capacitor
1N4001 Diode
2-pin Female receptacle
Hookup wire
5/8" x 1" Perf board
5/8" x 1" Double sided foam tape
Tools
The tools that I used in this project are:
Solder iron and Solder station
Hookup Wire
Diagonal Cutter
Pliers
X-Acto Knife
Wire Stripper
SolderSucker
Visit Our Store »
Go Pro Today »
Yes, it works exactly as Arduino. Because the micro controller has the Arduino's bootloader.
I like Arduino Leonardo too. With it built-in USB communication make it much more convenient to use than other Arduino.
You have a good eyes!
The TX and RX things got me confused all the time! Sorry about that!
Anyhow, the diagram had been revised and corrected.
Thanks
I was curious, is the ground pin needed? Or is there some what to get ground-age from a two pin resonator?
I'm afraid the resonator is unusable. Yes, the ground pin is needed!
If there was some part of the ground pin still there, you might want to try to solder to a wire to extend it.
I thought that was the case, but I figured I'd ask. thanks!
In this case you bought a crystal not the resonator.
Check if your crystal is 16MHz?
The resonator that I used already has built in capacitors.
So you will need two, either 18pF or 22pF ceramic capacitors.
Then connect one pin of a capacitor to one of the crystal pin, and connect the pin from the crystal to pin 9 or X1 on the micro controller.
And connect the other pin of the capacitor to ground.
With the second capacitor, connect to another pin of the crystal, an connect this pin from the crystal to pin 10 or X2 on the micro controller.
Connect the other pin of the capacitor to ground.
This should solve the problem!
Unfortunately, I don't have capacitors of that level in my stash, and I would have to order them (kind of live in a electronic part lacking part of the state) and I may just get the needed resonators.
However, that trick with the capacitors and crystals should be handy in the future!
I've actually started "groud breaking" on this, and I ran into one more snag (hopefully my last!). I have a MicroFTX (http://jim.sh/ftx/) and I don't know where the DTR lead of your FTDI port would go on that plug.
Thanks again for all the great help!!
I look at MicroFTX and saw that this FTDI converter used IC, FT230X instead of FT232R.
This chip only have 16 pins. There are only RTS# and CTS#. And it doesnot have DTR pin!
In your case, you could connect RTS from this breakout board (MicroFTX) to RESET pin on ATmega328. And connect CTS to ground.
But I do want to double check the pins, just to make sure I got it all right. So going from the breakout to the Ardunio:
GND > GND
CTS > GND
V > VCC
TX > TX
RX > RX
RTS > Pin one
TX from MicroFTX goes to pin number 2 (or D0) on Arduino
RX from MicroFTX goes to pin number 3 (or D1) on Arduino
This is very important.
Cheers!
Thanks.
I usually bought a pre-loaded boot loader from Adafruit.com
http://www.adafruit.com/products/123
The boot loader is Adafruit's own version of boot loader.
You can look at the details at the link stated earlier.
On the web page also mention how to upgrade the boot loader.
But sometime I used the standard boot loader available from Arduino IDE as well.
Thanks in advance!
There are a lot of existing Arduino Compatible board that's integrated the FTDI chip onto the board, for example, Adafruit's Boarduino. (http://www.adafruit.com/products/91).
Go for it! And shows us what you did.
If I could be anymore help please let me know.
However, the one thing I'm still a bit scared of is the power source. I'm thinking of hooking up the FTDI port behind the male header. That is to say, I'll have the wires from the FTDI port wired up on the inside side of the male header for the port. With that port wired up like that, will hooking up the power source damage it?
i want one
Or If I have a lot of money to hire peoples to bend the pins out, I will. ;)
Let's see. May be I'll come up with something.
Need to do a lot of feasible studies.
Thanks,
Where, When?
Can I attend?
Thanks
I like the way you placed The breadboard on top of the tin can.
I'm sure you would be able to do a lot of experiment while you were traveling!
Good job!
Thanks for showing.
2) Your cell phone could much more easily be used as a device for evil, with more electrical juice than a nine volt battery, and certainly more brains.
3) Put it in your luggage going under, and right on top.
4) Clear cases work best, not hidden in a mints box. Put a label on it.
5) Put LOTS of useless mini screws in with it, and maybe a micro screwdriver.
6) Tell them what it is - an all purpose testing circuit with programmable capabilities - you're studying to be an EE, building a toy for your kid, the list goes on. The truth is the fastest way through the line.
That being said, no matter what I do -
I get checked and sent over nearly every time I go to the airport, whether I am early, late, on time, you name it. Are 6'4" ponytailed white guys with beards are also being profiled...?
They had three of us off to the side one time at the airport - honest. On the flip side, I once accidentally carried my Leatherman in my carry-on, through the screener, and no one noticed, and that was 2 months after 9/11.
Hmm - I am usually carrying two cell phones and a laptop and a GalaxyTab - maybe my tech is being profiled?!
I used to carry similar type of PCB both prototyping board and the commercial available PCB with me when I was traveling abroad. And there was any trouble at all.
What I always do when I travel with these (improvised) electronic devices:
I would leave them in the carry on baggage, disconnected al the wires, and take the battery out of the battery holder. Turn the thing off.
I never carry them in my pants pocket, to avoid the pad down.
Here are the link to two well know airlines regarding the dangerous goods restriction, and electronic devices.
http://www.united.com/web/en-US/content/travel/baggage/devices.aspx
http://www.delta.com/traveling_checkin/baggage/dangerous_goods/index.jsp
This on is a link to safety travel web page regarding the battery and battery powered device - http://safetravel.dot.gov/index_batteries.html
