3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Panavise Mashup | Junior Head + Standard Base
Panavise makes a slew of bases, and attachments. Many of their parts are interchangable. You can mix a standard or low-profile base with numerous different vise attachments. However, not everything matches with everything else.
For example, the Panavise Junior vise is inexpensive and very handy, but is a self-contained unit: it includes both a base and vise. Since I have a standard low-profile base I use with other vise attachments, I wanted to see if I could make my Junior vise fit it to give me the added flexibility of the standard base and reduce the number of things I have around my workspace.
Turns out Panavise had the same idea and now sells just the Junior vise head, but I already had mine and didn't want to buy another ... so, here's how I did it.
Step 1Preparation
Preparation
Look over all the steps to get an idea of what's involved. Basically, you're going to cut of a  short piece of metal rod and saw/file a groove around one end for the "Junior" head to clamp too.
Simple.
The materials you'll need are:
1) 5/8" round rod of some sort. (I used zinc coated rod from Home Depot)
2) Hack saw (with a good, sharp blade)
3) Miter box (or, some other way to clamp/hold rod while you saw)
4) Flat and triangle files
5) Marker and ruler
6) Clamp
7) Small piece of wood to use as a stop
Find a good work surface. That will make the sawing easier. I used the floor. Not the best, but I threw down some canvas, and there you have it …
Before diving in, it's a good idea to take the head off the Junior vise just to see how it goes together. You'll see that the head has a pincer that fits into the shaped attachment on the base. That's what the groove in the rod is for.
The standard PanaVise base is just a simple clamp that holds a 5/8" rod.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bobber
