Introduction: PandaHall Tutorial on How to Make Vintage Necklaces With Tibetan Pendants
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
This tutorial will show you how to make vintage necklaces decorated with glass beads and pendants. If you are interested in Tibetan style necklace , never miss this one.
Step 1: Supplies Needed to Make Tibetan Style Necklace:
39mm Tibetan Style Pendant Cabochon Settings
25mm Clear Glass Cabochons
0.6~0.8mm Mini Glass Beads
30mm Tibetan Flower Pendant Cabochon
12mm Flat Round Glass Cabochons
15mm Wide Adhesive Tapes
Brass Jump Rings
Brass Lobster Claw Clasps
Antique Bronze Cross Chains
Nail Polish
Chain-Nose Pliers
Glue
Scissors
Step 2: Decorate the Tibetan Flower Pendant
1st, cut a piece of adhesive tapes, then put it in the flower pendant and make it tally with the inside shape of the pendant as picture shows;
2nd, cut the spare parts around the pendant like picture shows;
3rd, use glue to tightly connect the flower pendant with the flat round glass cabochon.
Step 3: Decorate the Big Tibetan Style Pendant With Glass Beads
1st, use the dark blue nail polish to paint the full oval shape of the Tibetan style pendant like picture shows;
2nd, put some mini glass beads into the pendant until it is fully filled like picture shows;
3rd, use some glue to tightly connect the big Tibetan pendant with the clear glass cabochon.
Step 4: Finish These Chain Necklaces
1st, attach 3 brass jump rings to the 3 Tibetan necklace pendants respectively like picture shows;
2nd, add 3 piece of antique bronze cross chains to the 3 pendants respectively;
3rd, attach 2 brass jump rings to the two ends of the chain and connect the two ends with a brass clasp;
4th, repeat the same steps to finish the other two chain necklaces as picture shows.
Step 5: Here Are the Final Look of These Vintage Necklaces:
Really elegant and chic design, which is proper to match any style of clothes in autumn. Do you like these Tibetan style necklaces? If you are interested in this kind of vintage pendant necklace, just take few minutes to try it. Do not forget to share us your crafts then!
