Pandahall Christmas Decoration- How to Make Pearl Beads Christmas Hanging Ornament
712
19
Published
Introduction: Pandahall Christmas Decoration- How to Make Pearl Beads Christmas Hanging Ornament
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Do you need Christmas decoration? Then follow me to see this Pandahall tutorial on how to make pearl beads hanging ornament.
Step 1: Supplies Needed for This Pearl Beads Christmas Hanging Ornament:
4mm Mixed Color Glass Pearl Beads
6mm Red Glass Pearl Beads
6mm Ivory Glass Pearl Beads
8mm Green Glass Pearl Beads
2mm White Glass Seed Beads
3mm White Pearl Acrylic Beads
6x3mm Silver Rhinestone Spacer Beads
Safety Pins
0.3mm Silver-Gray Tiger Tail
Transparent Fishing Thread Wire
Glue Gun
Scissors
Step 2: Make the First Part of the Pearl Beads Christmas Hanging Ornament
1st, slide an 8mm green pearl bead, two 3mm white pearl beads, two 6x3mm pearl beads, a 6mm red pearl bead onto a safety pin in order;
2nd, close the safety pin and make another seven same patterns;
3rd, cut off a piece of fishing wire and slide them onto the wire, then tighten the wire and make them into the below pattern;
4th, make a tie and cut off the extra part.
Step 3: Make the Second Part of the Pearl Beads Christmas Hanging Ornament
1st, cut off another piece of fishing wire and slide 2mm seed beads, 3mm white pearl beads, 6mm white pearl beads, 4mm red pearl beads onto the wire;
2nd, thread the wire through the next safety pin and slide the same beads onto the wire in each two space;
3rd, cross the wires through the last safety pin and slide ten 2mm seed beads and a 4mm red pearl bead onto the wire.
Step 4: Finish the Pearl Beads Christmas Hanging Ornament
1st, thread the wire through the next safety pin and continue to slide seed beads and red pearl beads;
2nd, keep continuing add beads until the whole pattern has been finished;
3rd, slide a 4mm green pearl bead onto a piece of wire and fix it onto the center part of the pattern;
4th, tighten the wire and cut off the extra part, then thread a piece of tiger tail through a 4mm red pearl bead (as shown in the picture).
Step 5: Here Is the Final Look of This Pearl Beads Christmas Hanging Ornament:
Now, can you make one similar pattern by yourself with following the steps one by one? Do not hesitate to make one if you like it and you just need to slide the beads in order. So collect this post and plan your crafts trip as soon as possible.
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
    3 Comments
    Thank you, they can be used in many jewelry making and you should try to do it.
