Pandahall Instruction on How to Make Chain Tassel Necklace With Glass Beads
Introduction: Pandahall Instruction on How to Make Chain Tassel Necklace With Glass Beads
Are you searching for chain necklace with beads? Look here, this tutorial will show you a chain tassel necklace with glass beads. Hope you will like it.
Step 1: Supplies You’ll Need in Making the Chain Necklace With Beads:
8MM Clear Abacus Electroplate Glass Beads
6 MM Clear Abacus Electroplate Glass Beads
8MM Faceted Round Glass Beads
14x8MM Faceted Glass European Beads
12x6MM Faceted Drop Electroplate glass Beads
10MM Golden Clear Rhinestone Spacer Beads
2MM Golden Spacer Beads
Golden Twisted Chain
0.2MM Transparent Fishing Wire
Golden Eyepins
Golden Ball Headpins
Golden Jump Rings
Golden Spring Clasps
Golden Cross Chain
Round Nose Pliers
Needle Nose Pliers
Side Cutting Pliers
Step 2: Make a Beaded Chain Pattern
1st, slide a drop faceted glass bead to an eyepin and wrap the eyepin to fix the bead;
2nd, slide a 8mm clear abacus glass bead to an eyepin and link it with the drop bead pattern together;
3rd, make a 6mm clear glass bead pattern with an eyepin and make a loop at the other end of it;
4th, cut 2 pieces of twisted chain, one chain is long and the other one is quite short, then link the chains with the bead patterns together as pictured.
Step 3: Finish the Beaded Chain Tassel
1st, repeat step 1 to make other more such beaded chains, then cut a piece of fishing wire, fold it in half and hang all the beaded chains together with it;
2nd, slide a blue glass European bead, a rhinestone spacer bead, a red faceted glass bead and a 2mm spacer bead to the wire.
Step 4: Finish the Chain Tassel Necklace
1st, cut a piece of twisted chain, then slide a blue faceted glass bead to an eyepin and attach it with middle of the chain;
2nd, make other 3 faceted glass bead pattern with 6mm and 8mm glass beads, then combine them together with the blue bead pattern, and attach a spring clasp to it as pictured;
3rd, cut another piece of twisted chain, and link it with the bead pattern, then slide a 8mm clear glass bead to a ball headpin and attach it with the chain as pictured;
4th, hang the beaded chain tassel to the jump ring as pictured.
Step 5: Here Is the Final Look of This Chain Necklace With Beads.
How do you like this chain necklace with beads? It is quite characteristic and chic, yes? Just try to make the personalized chain tassel necklace now, and I think you will like it really~
This project is inspired from:
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
