Introduction: Pandahall Original DIY - How to Make a Handmade Three-strand White Pearl Bracelet With Green Flower
In this Pandahall original DIY project, I'll show you a handmade three-strand white pearl bracelet with green flower. Follow me to see how it's made.
Step 1: Supplies in Making the Handmade Three-strand White Pearl Bracelet:
6mm Pink Bicone Faceted Glass Beads
4mm White Round Pearl Beads
10mm White Round Pearl Beads
3mm White Round Pearl Beads
6mm White Round Pearl Beads
20x5mm Golden 6-Hole Magnetic Slide Lock Clasps
12x8mm Green Faceted Drop Glass Beads
2mm Seed Beads
3mm Golden Round Beads
White Felt
Fishing Wire
0.3mm Silver Copper Wire
Needle
Glue Gun
Iron Scissor
Step 2: Make the First Part of the Green Bead Flower
1st, cut a part of fishing wire and thread a 10mm white round pearl bead to it. Then, cross the left fishing wire through the white pearl ebads and tighten (as shown in the picture);
2nd, cross the right fishing wire through the white pearl bead and tighten (as shown in the picture);
3rd, thread 2 seed beads to the fishing wire;
4th, use needle to cross the fishing wire through the second seed bead and tighten (as shown in the picture);
5th, thread another seed bead. Then, use needle to cross the fishing wire through the seed bead (as shown in the picture);
6th, refer to the above step to add more seed beads around the white pearl bead (as shown in the picture).
Step 3: Make the Second Part of the Green Bead Flower
1st, thread a 3mm golden round bead to the fishing wire;
2nd, use needle to cross the fishing wire through the golden bead and tighten (as shown in the picture);
3rd, refer to the above step to add more golden round beads around the seed beads (as shown in the picture).
Step 4: Make the Third Part of the Green Bead Flower
1st, thread a 6mm pink bicone faceted glass bead, a 4mm white round pearl bead and a 6mm pink bicone faceted glass bead in sequence to the fishing wire (as shown in the picture);
2nd, cross the fishing wire through the golden bead and the second pink bicone faceted glass bead in sequence. Then, thread a 4mm white round pearl bead and a 6mm pink bicone faceted glass bead in sequence to the fishing wire;
3rd, refer to the above steps to add more such bead patterns around the golden beads (as shown in the picture).
Step 5: Make the Rest Part of the Green Bead Flower
1st, cut a piece of 0.3mm copper wire and thread a 12x8mm green faceted drop glass bead and a 3mm white round pearl bead in sequence to it (as shown in the picture);
2nd, cross the right copper wire through the green faceted drop glass bead (as shown in the picture);
3rd, split the two copper wires apart;
4th, thread a green faceted drop glass bead and a 3mm white round pearl bead in sequence to the right copper wire;
5th, cross the copper wire through the green drop glass bead. Then, refer to the above steps to make more such bead patterns (as shown in the picture).
Step 6: Make the Rest Part of the Handmade Three-strand Pearl Bracelet
1st, use glue gun to attach the pink bead flower onto the green bead flower (as shown in the picture);
2nd, cut a circular white felt and use glue gun to attach it onto the back surface of the green bead flower (as shown in the picture);
3rd, cut a part of fishing wire and combine it with one hole of a 20x5mm golden 6-hole magnetic slide lock clasp. Then, hold the two fishing wires together and thread about 7 6mm white round pearl beads (as shown in the picture);
4th, thread more 6mm white round pearl beads and add the green bead flower by crossing the fishing wires through some beads of the green flower. Then, continue to thread 6mm white round pearl beads;
5th, combine the ends with the corresponding hole of the golden 6-hole magnetic slide lock clasp (as shown in the picture);
6th, refer to the above steps to make the other two strands (as shown in the picture).
Step 7: Here Is the Final Look of the Handmade Three-strand White Pearl Bracelet With Green Flower.
Do you like this handmade three-strand white pearl bracelet with green flower? This handmade three-strand white pearl bracelet will be good and unique gift for your friends during the summer holiday. If you're interested in this handmade three-strand white pearl bracelet, you can refer to the above steps to make one for yourself or friends!
