Pandahall Original DIY Project - How to Make a Handmade Flower Chain Necklace With Flower Tassels
633
14
Published
Introduction: Pandahall Original DIY Project - How to Make a Handmade Flower Chain Necklace With Flower Tassels
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
This Pandahall original DIY project is about a flower chain necklace with flower tassels. Follow me to see how to make the flower necklace.
Step 1: Materials and Tools Needed in DIY the Flower Chain Necklace:
10mm White Round Pearl Beads
6mm White Round Pearl Beads
8x6mm DarkSalmon Abacus Glass Beads
8x6mm Abacus Glass Beads
Peony Resin Flower Beads
Rose Resin Cabochons
Rose Flower Resin Beads
Golden Spring Clasps
Golden Jump Rings
Golden Eyepins
Golden Headpins
4x3mm Golden Chains
Golden Twisted Chain
Silver Circular Components
Golden Square Components
0.2mm White Fishing Wire
Needle Nose Plier
Round Nose Plier
Stainless-Steel Scissor
Glue Gun
Step 2: Make the First Part of the Flower Chain Necklace
1st, cut about 80cm 0.2mm white fishing wire. Then, thread 4 6mm white round pearl beads to it (as shown in the picture);
2nd, make some knots with the left wire and the right wire. Then, cross the left wire through adjacent white pearl bead and the cut off the excess wire (as shown in the picture);
3rd, thread 3 6mm white round pearl beads;
4th, combine the three white pearl beads together by crossing the wire through the left bottom white pearl bead of the four bead pattern, then crossing the wire through the two white pearl beads(as shown in the picture);
5th, refer to the Step 3 and Step 4 to make another such bead pattern. Then, add a 6mm white round pearl bead and cross the wire through the leftmost white pearl bead. Then, add a 6mm white round pearl bead and cross the wire through the rightmost white pearl bead (as shown in the picture);
6th, tighten the wire.
Step 3: Make the Second Part of the Flower Chain Necklace
1st, add a 6mm white round pearl bead and cross the wire through the adjacent white pearl beads. Refer to this step to add 3 more 6mm white round pearl beads (as shown in the picture);
2nd, add a pink abacus glass beads and cross the wire through the white pearl beads (as shown in the picture);
3rd, refer to the above step to add 3 more pink abacus glass beads (as shown in the picture);
4th, refer to the above steps to make another white pearl beads and pink glass beads pattern and a white pearl beads and blue glass beads pattern (as shown in the picture);
5th, thread a golden eyepin to the three bead patterns respectively. Then, make a hoop on the other end of the three eyepins one by one(as shown in the picture).
Step 4: Make the Third Part of the Flower Chain Necklace
1st, combine 3 8x6mm dark salmon abacus glass beads, a pink abacus glass bead, 2 blue abacus glass beads, 4 6mm white pearl beads and 5 clear abacus glass beads with golden headpins (as shown in the picture);
2nd, cut a piece of 4x3mm golden chain. Then, add a pink glass bead, a white pearl bead, a blue glass bead and a clear glass bead to the chain(as shown in the picture);
3rd, cut 4 pieces of 4x3mm golden chains. Then, add the beads to the chains (as shown in the picture);
4th, combine the five chains together through a golden jump ring. Then, add a silver circular component to the top through jump rings (as shown in the picture);
5th, use glue gun to attach a white peony resin flower bead, 2 purple rose flower resin beads and a yellow rose flower resin bead onto the silver circular component (as shown in the picture);
6th, use glue gun to attach a 10mm white round pearl bead, a purple rose flower resin bead, 2 6mm white round pearl beads and a pink abacus glass bead onto the silver circular component (as shown in the picture).
Step 5: Make the Rest Part of the Flower Chain Necklace
1st, use glue gun to attach a red peony resin flower bead and a pink peony resin flower bead onto a golden square component respectively (as shown in the picture);
2nd, add the white pearl bead ball pattern with blue glass beads (as shown in the picture);
3rd, cut two equal pieces of golden twisted chain and combine them with the white pearl bead ball pattern with blue glass beads. Then, add the red peony resin flower bead pattern and the pink peony resin flower bead (as shown in the picture);
4th, cut two equal pieces of golden twisted chain. Then, combine them with the two peony resin flower bead patterns respectively. Then, add the two white pearl bead ball pattern with pink glass beads to the two sides respectively. Cut two equal pieces of golden twisted chain and combine them with the two white pearl bead ball patterns (as shown in the picture);
5th, add a 10mm white pearl bead to the left chain and a golden spring clasp to the right chain (as shown in the picture);
Step 6: Connect the Two Ends of the Flower Chain Necklace Together.
Step 7: Here Is the Final Look of the Flower Chain Necklace With Flower Tassels.
Do you like this handmade flower chain necklace with flower tassels? The three white pearl bead ball patterns may take you some time. So, be patient during the making of the white pearl bead ball patterns. Have a try if you like this flower chain necklace.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
