Pandahall Original Project--How to Make Delicate Choker Necklace With Pearl Beads
1,734
60
4
Published
Introduction: Pandahall Original Project--How to Make Delicate Choker Necklace With Pearl Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Love beading necklace? If yes, you must fall in love with today’s Pandahall original project--how to make delicate choker necklace with pearl beads!
Step 1: Materials Needed for the Pearl Beads Necklace:
4mm Black Round Pearl Beads
6mm White Round Pearl Beads
8mm White Round Pearl Beads
10mm White Round Pearl Beads
12mm White Round Pearl Beads
Iron Jumprings
17x8mm Platinum Tone Textured Triple Strand Box Clasp
Headpins
0.2mm Clear Transparent Fishing Thread
Needle
Scissors
Side Cutting Pliers
Flat Nose Pliers
Round Nose Pliers
Step 2: Prepare the Base of a Beading Flower
1st, trim off a proper length of fishing thread and cross it through a needle;
2nd, slide a 10mm white pearl bead on the thread and then add five 4mm black pearl beads near it;
3rd, add a 4mm black pearl bead on the other side of the thread and cross the two sides of it;
4th, add four 4mm round pearl beads on one side of the thread and form a round circle like below;
5th, continue to slide five black pearl beads and cross the needle through the next black pearl bead.
Step 3: Make a Beading Flower
1st, slide five black pearl beads on the needle and thread it through the outer two black pearl beads;
2nd, repeat the same ways three times and we get a beading flower;
3rd, continue to slide five black pearl beads on the needle and then thread it through the next two black pearl beads;
4th, repeat the way four times and we get a bigger beading flower.
Step 4: Make the Base of a Beading Square
1st, cut off a piece of fishing thread and slide five black pearl beads and a 8mm white pearl bead on it like below, then cross it;
2nd, slide three black pearl beads on one side of the thread and form a round circle;
3rd, slide four black pearl beads on the needle and thread it through the next black pearl bead;
4th, repeat the way above three times.
Step 5: Finish the Beading Square
1st, slide five black pearl beads on the needle and thread it through the opposite black pearl bead;
2nd, repeat the way above three times and we get a beading square;
3rd, make other beading squares in the same ways, meanwhile, the white pearl beads in the center is 8mm and 6mm, and the amount of each type is four;
4th, combine the beading flower and beading squares together with fishing thread and the sequence is from big to small and the beading flower is in the center.
Step 6: Add the Box Clasp
1st, add four black pearl beads and a box clasp on the thread, then continue to add four black pearl beads on it and thread the needle through the next black beads forming a round circle;
2nd, slide four black pearl beads on the other side of thread , then thread it through the third circle of the box clasp and continue to add a black pearl bead on it;
3rd, hide the fishing thread by crossing it through the beading path and then trim off excess thread;
4th, add the box clasp on the other side in the same ways.
Step 7: Finish the Delicate Pearl Beads Necklace
1st, thread a headpin through a 12mm white pearl bead and make a loop at the bottom;
2nd, hang a jumpring on the pearl bead and then connect the jumpring with the beading necklace like below.
Step 8: Time for the Final Look of the Choker Necklace:
Wow, what a amazing pearl beads choker necklace! Don’t you think so guys? It suits an evening dress a lot! If you are interested in the Pandahall original project, go ahead! If you have some confusion about it, please feel free to ask me or leave a comment. Hope you a nice try and have a beautiful day~
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    4 Discussions
    Thank you. Just make one for yourself!
