Introduction: Pandahall Tutorial - How to DIY a Flower Choker Necklace Step by Step
Do you like flower choker necklace? In this simple Pandahall tutorial, I’ll show you how to DIY a flower choker necklace step by step.
Step 1: Supplies Needed in DIY the Flower Choker Necklace Step by Step:
16x8mm Beige Pearl Beads
12mm Yellow Faceted Gemstone Beads
8mm Round Turquoise Beads
6mm Round Turquoise Beads
4mm Round Turquoise Beads
6mm Clear Glass Beads
Silver Jump Rings
Platinum Bead Tips
Silver Lobster Claw Clasps
Tiger Tail
Stainless-Steel Scissor
Needle Nose Plier
Round Nose Plier
Step 2: Make a Bead Flower for the Flower Choker Necklace
1st, cut a piece of tiger tail with a length about 65cm. Then, thread a 12mm yellow faceted gemstone bead and cross the right tiger tail through the yellow faceted gemstone bead;
2nd, thread a 16x8mm beige pearl bead, a 6mm round turquoise bead and a 16x8mm beige pearl bead in sequence to the right tiger tail. Then, cross the right tiger tail through the gap between the 12mm yellow faceted gemstone bead and the tiger tail, and then cross the tiger tail through the second 16x8mm beige pearl bead (as shown in the picture);
3rd, repeat the above step four times.
Step 3: Make 4 More Bead Flowers for the Flower Choker Necklace
1st, thread a 6mm clear glass bead, a 8mm round turquoise bead and a 6mm clear glass bead in sequence to the right side of the bead flower made just now. Then, refer to Step 1 to make another bead flower;
2nd, repeat the above step three times.
Step 4: Make the Rest Part of the Flower Choker Necklace
1st, thread a 6mm clear glass bead, a 4mm round turquoise bead, a 6mm clear glass bead and a 8mm round turquoise bead in sequence to the right tiger tail. Repeat this step twice;
2nd, refer to the above step to thread beads to the left tiger tail;
3rd, add platinum bead tips and silver jump rings on the two sides of the tiger tail respectively. Then, connect the two ends of the flower choker necklace together through a silver lobster claw clasp.
Step 5: Here Is the Final Look of the Flower Choker Necklace.
Wearing this flower choker necklace, you'll look more elegant. During the DIY process, you can also choose beads in other colors. A large charm beads will give the flower choker necklace a finished look and draw attention to the graceful lines of the neck. If you are interested in this DIY choker necklace, just have a try!
