Introduction: Pandahall Tutorial - How to Make a Blue Glass and Seed Bead Bracelet
In this Pandahall tutorial, you can see a blue glass and seed bead bracelet. Follow me to see how to make it if you like this blue glass and seed bead bracelet.
Step 1: Supplies Needed in DIY the Blue Glass and Seed Bead Bracelet:
6mm Blue Bicone Glass Beads
3mm Blue Seed Beads
2mm Silver Round Seed Beads
2x1.5mm Blue Round Seed Beads
15x11.5x6mm Brass Slide Lock Clasps
Clear Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Blue Glass and Seed Bead Bracelet
1st, cut a part of clear fishing wire. Then, thread 4 6mm blue bicone glass beads and 4 2mm blue seed beads to it (as shown in the picture);
2nd, make a hoop with the beads by crossing the right wire through the blue glass beads and blue seed bead (as shown in the picture);
3rd, make a knot with the two wires;
4th, combine the two wires together and thread them through a needle. Then, thread a 2mm blue seed bead to the wires and cross the wires through the adjacent blue glass bead;
5th, refer to the above step to add a 2mm blue seed bead beside the other three blue seed beads one by one (as shown in the picture).
Step 3: Make the Second Part of the Blue Glass and Seed Bead Bracelet
1st, refer to the above step to add a 2mm blue seed bead beside the blue seed beads one by one (as shown in the picture);
2nd, thread 2 2mm blue seed beads, a 3mm blue seed bead and 2 2mm blue seed beads to the wires;
3rd, make a semi-circle around the blue glass bead with the seed beads by crossing the wires through the 2mm blue seed bead(as shown in the picture);
4th, thread a 2mm silver round seed bead to the wires. Then, cross the wires through the 2mm blue seed bead (as shown in the picture).
Step 4: Make the Third Part of the Blue Glass and Seed Bead Bracelet
1st, refer to the Step 2 to make three more bead patterns to the other three sides (as shown in the picture);
2nd, thread 6 2mm blue seed beads to the wires;
3rd, make a hoop with the blue seed beads by crossing the wires through the two blue seed beads (as shown in the picture);
4th, cross the wires through the silver seed bead (as shown in the picture);
5th, add a silver seed bead and then cross the wires through the silver seed bead (as shown in the picture);
6th, add another silver seed bead and then cross the wires through the two silver seed beads (as shown in the picture).
Step 5: Make the Fourth Part of the Blue Glass and Seed Bead Bracelet
1st, thread the wires through the two 2mm blue seed beads beside the silver seed beads (as shown in the picture);
2nd, refer to the above steps to make three more such bead patterns (as shown in the picture);
3rd, add a 2mm blue seed beads and then thread the wires through the three 2mm blue seed beads (as shown in the picture);
4th, add 2 silver seed beads and thread the wires through the right silver seed bead (as shown in the picture);
5th, add a silver seed bead and thread the wires through the left silver seed bead (as shown in the picture);
6th, add two silver seed beads and thread the wires through the three 2mm blue seed beads (as shown in the picture).
Step 6: Make the Fifth Part of the Blue Glass and Seed Bead Bracelet
1st, add a 2mm blue seed bead and thread the wires through the three 2mm blue seed beads;
2nd, refer to the above steps to the other three sides (as shown in the picture);
3rd, add 4 silver seed beads and thread the wires through the two right silver seed beads (as shown in the picture);
4th, add a silver seed bead and thread the wires through the top silver seed bead in the middle (as shown in the picture).
Step 7: Make the Sixth Part of the Blue Glass and Seed Bead Bracelet
1st, add a silver seed bead and thread the wires through the left two silver seed beads (as shown in the picture);
2nd, add 4 silver seed beads and thread the wires through the 2mm blue seed bead (as shown in the picture);
3rd, add 4 silver seed beads and thread the wires through the two silver seed beads (as shown in the picture);
4th, refer to the above steps to make three more such patterns to the other three sides (as shown in the picture);
5th, add a silver seed bead and thread the wires through the left 7 silver seed beads (as shown in the picture).
Step 8: Make the Seventh Part of the Blue Glass and Seed Bead Bracelet
1st, add a silver seed bead and thread the wires through the silver seed beads (as shown in the picture);
2nd, refer to the baove steps to make three corresponding patterns on the other three sides (as shown in the picture);
3rd, refer to the baove steps to make 5 more such blue beaded flower patterns (as shown in the picture);
4th, cut another piece of clear fishing wire and thread it through one hole of the 15x11.5x6mm brass slide lock clasp. Then, add 2 silver seed beads to the right wire and 3 silver seed beads to the left wire (as shown in the picture).
Step 9: Make the Eighth Part of the Blue Glass and Seed Bead Bracelet
1st, cross the right wire through the bottom silver seed bead and tighten (as shown in the picture);
2nd, hold the wires together and thread a 2mm blue seed bead, a silver seed bead, a 3mm blue seed bead, a silver seed bead and a 2mm blue seed bead in sequence;
3rd, cross the wires through the silver seed beads of one blue bead flower (as shown in the picture);
4th, add 3 silver seed beads, a 2mm blue seed bead, a silver seed bead, a 3mm blue seed bead, a silver seed bead, a 2mm blue seed bead and 3 silver seed beads in sequence.
Step 10: Make the Ninth Part of the Blue Glass and Seed Bead Bracelet
1st, thread the wires through the silver seed beads of another blue bead flower pattern (as shown in the picture);
2nd, refer to the above steps to add the other two blue bead flower patterns (as shown in the picture);
3rd, combine the wires with the corresponding hole of the brass slide lock clasp (as shown in the picture);
4th, cross the wires through the two silver seed beads (as shown in the picture);
5th, continue to thread the wires through the silver seed beads (as shown in the picture);
6th, continue to thread the wires through the seed beads (as shown in the picture).
Step 11: Make the Rest Part of the Blue Glass and Seed Bead Bracelet
1st, add 2 silver seed beads and thread the wires through the seed beads (as shown in the picture);
2nd, add 2 silver seed beads and thread the wires through the silver seed beads;
Step 12:
3rd, refer to the above steps to add silver seed beads to the other three linking parts (as shown in the picture);
4th, refer to the above steps to link the corresponding side (as shown in the picture).
Step 13: Here Is the Final Look of the Blue Glass and Seed Bead Bracelet.
Do you love the DIY blue glass and seed bead bracelet? This blue glass and seed bead bracelet is very suitable to wear during summer. It's a little complicated to make the blue bead flower bracelet. Please be patient during the making process.
