Pandahall Tutorial - How to Make a Pair of 2-Hole Seed Bead Butterfly Earrings
768
18
Posted in CraftJewelry
Introduction: Pandahall Tutorial - How to Make a Pair of 2-Hole Seed Bead Butterfly Earrings
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
In this Pandahall tutorial, I'll show you how to make a pair of 2-hole seed bead butterfly earrings. Hope you like the 2-hole seed bead butterfly earrings.
Step 1: Supplies Needed in DIY the 2-hole Seed Bead Butterfly Earrings:
Blue 2-Hole Seed Beads
Orange 2-Hole Seed Beads
2mm White Round Seed Beads
Silver Earring Hooks
0.2mm White Fishing Wire
Stainless-Steel Scissor
Round Nose Plier
Step 2: Make the First Part of the 2-hole Seed Bead Butterfly Earrings
1st, cut a piece of 0.2mm white fishing wire and thread it through a needle. Then, add an orange 2-hole seed bead, 8 blue 2-hole seed beads and 5 2mm white round seed beads (as shown in the picture);
2nd, make a hoop with the beads by crossing the wire through the orange 2-hole seed bead;
3rd, make a knot with the wires. Then, add 2 2mm white round seed beads to the wire and cross it through the other hole of the orange 2-hole seed bead (as shown in the picture);
4th, add 2 2mm white round seed beads to the wire and cross it through the adjacent 2mm white round seed bead and the adjacent blue 2-hole seed bead in sequence (as shown in the picture).
Step 3: Make the Second Part of the 2-hole Seed Bead Butterfly Earrings
1st, add a blue 2-hole seed bead and cross the wire through the other hole of the adjacent blue 2-hole seed bead. Then, add 2 orange 2-hole seed beads and cross the wire through the other hole of the adjacent blue 2-hole seed bead (as shown in the picture);
2nd, add a blue 2-hole seed bead and cross the wire through the other hole of the adjacent blue 2-hole seed bead (as shown in the picture);
3rd, add 2 2mm white round seed beads and cross the wire through the adjacent 2mm white round seed bead. Then, add another 2 2mm white round seed beads and cross the wire through the other hole of the adjacent blue 2-hole seed bead (as shown in the picture);
4th, add a blue 2-hole seed bead and cross the wire through the other hole of the adjacent blue 2-hole seed bead. Then, add 2 orange 2-hole seed beads and cross the wire through the other hole of the adjacent blue 2-hole seed bead. Add a blue 2-hole seed bead and cross the wire through the other hole of the adjacent blue 2-hole seed bead (as shown in the picture).
Step 4: Make the Third Part of the 2-hole Seed Bead Butterfly Earrings
1st, add a 2mm white round seed bead and cross the wire through the top white round seed bead (as shown in the picture);
2nd, add another 2mm white round seed bead and cross the wire through the adjacent white round seed bead. Then, add another 2mm white round seed bead and cross the wire through the other hole of the adjacent blue 2-hole seed bead(as shown in the picture);
3rd, add 2 2mm white round seed bead and an orange 2-hole seed bead, and cross the wire through the other hole of adjacent blue 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the other hole of adjacent orange 2-hole seed bead (as shown in the picture);
4th, add 2 2mm white round seed beads and cross the wire through the other hole of adjacent orange 2-hole seed bead (as shown in the picture);
5th, add an orange 2-hole seed bead and cross the wire through the other hole of adjacent blue 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the white round seed beads (as shown in the picture);
6th, refer to the above steps to add orange 2-hole seed beads and white round seed beads to the other side (as shown in the picture).
Step 5: Make the Fourth Part of the 2-hole Seed Bead Butterfly Earrings
1st, add 2 white round seed beads and cross the wire through the other hole of the adjacent orange 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the wire through the other hole of the adjacent orange 2-hole seed bead (as shown in the picture);
2nd, add a white round seed bead and cross the wire through the adjacent 2 white round seed beads. Then, add 2 white round seed beads and cross the wire through the other hole of the adjacent orange 2-hole seed bead(as shown in the picture);
3rd, add an orange 2-hole seed bead cross the wire through the other hole of the adjacent orange 2-hole seed bead (as shown in the picture);
4th, add 2 white round seed beads and cross the wire through the white round seed beads(as shown in the picture);
5th, add 2 white round seed beads and refer to the above steps to add white round seed beads and orange 2-hole seed bead(as shown in the picture);
6th, add 2 white round seed beads and an orange 2-hole seed bead, then cross the wire through the other hole of the adjacent orange 2-hole seed bead. Then, add a white round seed bead and cross the wire through the 5 white round seed beads. Then, add another white round seed bead (as shown in the picture).
Step 6: Make the Rest Part of the 2-hole Seed Bead Butterfly Earrings
1st, refer to the above steps to add more white round seed beads and cross the wire through the white round seed beads and orange 2-hole seed bead (as shown in the picture);
2nd, cross the wire through the external white round seed beads. Then, make a knot and cut off the excess wire(as shown in the picture);
3rd, add a silver earring hoop on the top of the 2-hole seed bead butterfly earring;
Step 7: Here Is the Final Look of the 2-hole Seed Bead Butterfly Earrings.
What do you think of the 2-hole seed bead butterfly earrings? As you can see from the above description, it's a bit complicated to bead the butterfly. So, be patient and careful during the DIY process.
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
