Pandahall Tutorial on How to Make Handmade Flower Beaded Chocker Necklace
917
23
Posted in CraftJewelry
Introduction: Pandahall Tutorial on How to Make Handmade Flower Beaded Chocker Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
This tutorial will tell you a tutorial about a handmade choker necklace, if you are searching for choker necklace, then this one will be a good choice for you~
Step 1: Supplies You’ll Need in Making the Made Choker Necklace:
4MM Round White Glass Pearl Beads
8MM Round White Glass Pearl Beads
6MM Bicone Clear Glass Beads
6MM Bicone Red Glass Beads
0.2MM Transparent Fishing Wire
Spring Ring Clasps
Jump Rings
Scissor
Step 2: Make a Basic Beaded Pattern
1st, cut a piece of fishing wire and slide 3 4mm white pearl beads, a ring clasp and 2 4mm white pearl beads to it;
2nd, cross one end through the last bead to form a loop, make a knot and cut one end of it;
3rd, slide 3 red bicone glass beads and 2 4mm pearl beads alternatively to the wire and then cross the end of it through the pearl bead as pictured.
Step 3: Add More Bead to the Bead Pattern
1st, cross the wire through the red glass bead and pearl bead, then slide 3 4mm pearl beads and 2 8mm pearl beads alternatively to the wire;
2nd, cross the wire through the red glass bead and along the bead loop;
3rd, slide a 4mm pearl bead, a clear bicone glass bead and 4 4mm pearl bead to the wire, then cross the wire through the 2nd pearl bead and add a clear glass bead, a 4mm pearl bead, an 8mm pearl bead and a 4mm pearl bead to it;
4th, cross the wire through the 8mm pearl bead on the ready loop, along the beads and then add 3 4mm pearl beads, an 8mm pearl bead and a red glass beads to the wire in order;
5th, cross the wire through the 8mm pearl bead to form a loop as pictured.
Step 4: Make More Bead Loops
1st, slide 3 4mm pearl beads alternatively to the wire and cross it through the red glass bead, then cross it through the loop;
2nd, repeat above steps to make more such bead loop patterns till the length is fit to you, then make a knot with the wire.
Step 5: Finish the Flower Beaded Necklace
1st, slide 4 4mm pearl beads to the wire, add a jump ring to it and cross the wire along the beads to fix it;
2nd, cut off the excess wire and then this handmade choker necklace is finished.
Step 6: The Final Look of the Handmade Choker Necklace
Do you like this handmade choker necklace? Have you learnt the detailed steps one how to make beaded flower necklace? It is so lovely that it deserves your time to have a nice try~
    • Spotless Contest
      Spotless Contest
    • Slow Cooker Challenge
