Hi!
This instructable will show you how to easily throw together some movieprop.
Created to simulate the effect of when opening a chest full of gold, or a box filled with mystery. <-- Hence the title "Pandoras Box"
It was done in about 5-6h.
Step 1: What do we need?
First of all, we need a fancy box.
Create one yourself, or buy one.
This is a jewelrybox from the beginning, but now it contains all kinds of evil.
It has a handy mirror inside to help reflect the light from the inside.
Then we need :
  1. Thermal compund (?) To transfer heat from the
  2. LED Diode. In this case a powerful XML-T6 from Cree.
  3. LM350- Voltage Regulator, but we will be using it for Current Control.
  4. A huge heatsink.
  5. 9V Battery or Minimum 6,5V (The more exact to 6,5, the better)
  6. Resistors at 0.47 Ohm. 5W+ capable preferrably.
  7. Microbreaker. When pressed, the light is OFF, when not pressed (lid up) it's on.
  8. Screw/s
  9. Cables cables and cables!
  10. Coloured plastic! - Thin
  11. A normal switch, I/O.
  12. Misc. Tools like scissors, screwdriver etc.
All in all, this will cost you around 30-50$ to create.
But if you scavenge alot, you will get away with 10$
wsround says: Jan 24, 2013. 3:02 PM
I don't think I want something that gets so hot that it needs a heat sink to dissipate the heat generated in a small wood or cardboard box.
Dufva (author) in reply to wsroundJan 24, 2013. 3:19 PM
You can change it for multiple 1W LEDs, they dissipate very low heat
Dufva (author) in reply to wsroundJan 24, 2013. 3:18 PM
You dont necessarily need this powerful LED, and it was created for filming shorts with :)
So it's on for about 20ses max.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
