Paneer Butter Masala, an Indian Delicacy Made With Home-Made Cheese
1,671
33
Posted
Introduction: Paneer Butter Masala, an Indian Delicacy Made With Home-Made Cheese
Paneer Butter Masala is an Indian delicacy made with home-made vegetarian cheese. This dish is very simple to make and tastes so good. You can even try it with any cheese available with you.
The cheese I have used here is popularly known in India as Paneer and made by vegetarian method without the use of rennet. You can see my instructable here on how to make vegetarian cheese without using rennet:
https://www.instructables.com/id/How-to-Make-Paneer...
Step 1: Cut Paneer Into Cubes
The home-made cheese weighed about 150 grams and is about one centimetre thick. So, cut the cheese into one centimetre cubes using a kitchen knife. Do not discard the loose particles from the edges as they can also be used in making the dish.
Step 2: Ingredients
In addition to cheese, you need the following ingredients to make the dish. These ingredients are for about 150 grams of cheese, so adjust the quantity as required.
  • 4 numbers medium sized tomatoes
  • 100 grams of cashew nuts
  • Three medium sized onions
  • Two to three Garlic cloves
  • About a cubic inch of Ginger
  • One and half a teaspoon of Red chilli powder (Adjust it to your own taste)
  • One teaspoon of Cumin seed powder
  • One teaspoon of Garam Masala powder (It is a powdered mixture of different spices)
  • About half a teaspoon of Asafoetida powder
  • A tablespoon of cooking oil
  • About 50 grams of butter
  • A bunch of Coriander leaves for garnishing
  • Salt to taste
Step 3: Make Tomato Puree
  • Boil the tomatoes for about five minutes. This will enable to remove the skin of the tomatoes
  • Cut the tomatoes into pieces and make puree using a mixer-grinder
Step 4: Make Cashew Paste
  • Soak the Cashew nuts in water for about five minutes
  • Drain out the water and grind the soaked cashew nuts into rough paste
Step 5: Chop Onions
  • Remove dry skin of onions
  • Chop them into fine pieces
Step 6: Ginger Garlic Paste
  • Shuck garlic and remove skin from ginger pieces
  • Grind the ginger garlic into a paste.
Step 7: Preparation Step-1
  • Heat a frying pan over medium flame and add cooking oil
  • Add chopped onions and Ginger / Garlic paste and cook till raw smell disappears
  • Add all other spices and mix well
  • Add salt to taste
  • Add tomato puree to the mixture and cook for a few minutes
  • Add cashew nut paste and mix well
Step 8: Preparation Step-2
  • Now add butter to the pan cook till it melts and mixes with the other ingredients
  • Add little amount of water if required
  • Add paneer cube, cover the pan and cook for about five minutes
Step 9: Transfer From Pan
  • After five minutes, remove the lid and switch off the flame
  • Transfer the cooked Paneer Butter Masala to a serving dish
  • Garnish with chopped coriander leaves
This can be used as side dish with rice, chappati and bread. It tastes so good you will love it
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    2 Comments
    This looks great, will be saving this to make later!
