Panel Poster - Make Your Own Giant Posters
 by laboratory424
We wanted some ultra-giant posters around the lab. The costs and limitations were too much, so we created the Panel Poster. An inexpensive technique to create huge, professional-looking posters of any image you want using simple, raised, paper panels.
A Panel Poster is an image printed across multiple sheets of card stock and folded into panels measuring about 6.5 x 8.5 x 1/2 inches (16.5 x 21.6 x 1.27 cm). This allows you to produce large, custom posters at a fraction of the cost. The raised panel design gives the poster a professional appearance, is simple to install with our non-permanent, double-stick foam blocks, and panels can easily be replaced as needed.
This instructable shows you how to generate, print, and, build your panels. The instructable, How to install Panel Posters, shows you how to install, remove, and reuse panel posters.
  • Buy scoring, assembly, and mounting materials.
  • Learn more details on the project page.
  • See more pictures in our Panel Poster gallery.
Here's a 5:55 minute video showing how to build a panel.
Step 1: Get Parts, Tools, and Materials
For Printing
  • 110 lb, 8.5" x 11" (216mm x 279mm) white card stock (or similar)
  • Ruler
  • USB Thumb Drive (optional)
  • Access to a printer or a print service provider
For Building
  • Panel poster score guide (included in Starter Pack)
  • Double-stick tape strips (included in Starter Pack)
  • Hobby knife, scoring tool (or similar)
  • Scissors
  • Self healing mat (or similar)
  • Tweezers (optional)
  • Vinyl gloves (optional)
Dream Dragon says: Apr 13, 2012. 5:10 AM
That looks really cool, thanks for sharing your project(s). how robust are they though? It seems like you might have to instal them in locations were people are not likely to be able to bash, bump or rub against them.
laboratory424 (author) in reply to Dream DragonApr 13, 2012. 10:06 AM
They are sturdy enough to remove/replace as many times as needed, and can take mild rubbing and bumping without any noticeable damage. However, if someone tries to walk through your fake corridor panel poster they will get squished beyond repair. If that's the case, you simply print and build duplicates of the damaged panels and swap them out. Easy, cheap...watching someone walk into the panel poster, priceless (please post video). :)
dimtick says: Apr 13, 2012. 9:10 AM
This i really cool.
I did a project a few years ago where I took an old window, replaced the panes with mirrors and hung it as a dressing mirror. I think it would be very cool to use this method to mount a poster in the window. You wouldn't even want to remove the window panes, simply mount the posters behind so it's like your looking thru the window.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
