Introduction: Panning Timelapse Rig From a Kitchen Timer
Yes, I have a bit of a timelapse fetish. I got a kitchen timer for just $3 and made this awesome panning timelapse rig that circles 360 degrees in 1 hour.
First test out on the water!
_______________
Notable Materials:
> Kitchen timer
> 1/4-20 bolt
> 1/4-20 t nut
> Quick set epoxy
> Plywood scrap
Notable Tools:
> Bandsaw
> Disk sander
> Drill press
> Angle grinder
Step 1: Disassembly and Plywood
Picture of Disassembly and Plywood
So it just starts with this cheapo kitchen timer that was only a few bucks at the big box store. All it takes to disassemble it from it's casing is a screw in the back.
I take the timer mechanism and put it on top of a piece of plywood to trace it out.
The circle is cut out to rough size on the bandsaw and then I drill a hole through the center and use this on my disk sander to sand it down to a perfect circle.
Step 2: Drilling the Dial
Picture of Drilling the Dial
I pull the top of the timer off so I can attach a bolt there for a way to mount the camera.
I first drill through the bottom of it to locate the center of the dial and then bring it over to my drill press to drill a 1/4" hole through the top deep enough to mount a bolt.
While I'm there, I also drill out the plywood base, both for the tripod bolt to fit into and also for the base of the threaded t-nut that I am going to be installing in the plywood.
Step 3: Preparing the Bolt
Picture of Preparing the Bolt
I grab a 1/4-20 bolt from my hardware drawer and insert it into the dial so I can mark it to cut to length.
The bolt is mounted in a clamp and cut down to size with my angle grinder.
Step 4: Assembly
Picture of Assembly
Now it's just a matter of assembly. I mix up some quick set 2-part epoxy and use it both in the plywood base and also in the dial.
The t-nut is installed in the plywood base and then the bolt is installed in the dial.
I also use the same 2-part epoxy on the plywood base in order to fasten it to the timer mechanism.
Step 5: Final Steps
Picture of Final Steps
The pieces are then all mounted together. The tripod threads into the t-nut in the plywood base and the bolt in the dial is threaded into the camera.
Then it's just a matter of cleaning it up and painting it to make it look a little more sleek.
It's super easy to mount it by just threaded it on between the tripod and the camera, almost too easy for the really cool results.
Step 6: Glamour Shots!
Picture of Glamour Shots!
Thanks for checking out the build! Be sure to watch the video for the full experience:
Thirsty for more? You can also find me in other places on the interwebs!
My Website: Essentially my entire life
https://www.jackmanworks.com
YouTube: Me, in moving picture form
https://www.youtube.com/jackmanworks
Instagram: Preview my projects as they progress #nofilter
https://www.instagram.com/jackman_works
Twitter: Riveting thoughts, in very small doses
https://www.twitter.com/jackmanworks
Note: This post contains affiliate links. Thank you for supporting what I do!
dekeros (author)2017-11-14
Quite clever. Well done!
Skyfinder (author)2017-05-23
Brillant anyway...
579views
12favorites posted 11 May...Finalist vs projects with 5 more views and favorites posted 1 month before...explain me this please...
Deus Tempestas (author)2017-05-16
*slaps self on the forehead*
Brilliantly simple! Well done.
ThirdEarthDesign (author)2017-05-14
That's a novel idea!
About This Instructable
925views
22favorites
License:
Bio: I've been "making" for 10 years now - Jackman Works was founded in 2009 to showcase my creations and I have been growing it a ... More »
More by JackmanWorks:Pallet Wood End Grain CoastersBuilding "A Christmas Story" Leg Lamp (the MANLY Version)(Lasers & Lathe) Wooden Magnifying Glasses - Corporate Awards
Add instructable to:
