3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Papaya Picker
Papaya Picker
Papays are big fruit; heavy, and often high up.
After getting the picker fingers around the fruit, you pull the string to close the flexible "fingers".  Twist the fruit to break the stem, and lower the fruit to the ground.
Although this design works, and the closing fingers are a neat mechanism to play with, you can find a stronger design with no moving parts on my other instructable;  http://www.instructables.com/id/Heavy-Duty-Papaya-Picker    The heavy-duty design has given me years of service with no problems.
Step 1Safety while heat forming PVC
We love plastics for what they do for us, but plastic manufacture and decay tend to pollute the environment and negatively affect our health.
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
I do work inside, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. PLAY WITH FIRE -- CAREFULLY.
23 comments
Apr 28, 2012. 9:22 PMMauibuck says:
I made one following your instructions and it works GREAT. Bet I end up making 20 for friends. Many thanks for a very innovative solution to a problem I've had for several decades. The fingers on the wire baskets wrecked many fruit. Never again. Mahalo nui loa (Many thanks in Hawaiian)
Oct 2, 2010. 2:18 AMdawoj says:
Simple & good I love this. Is it strong enough?
Feb 24, 2010. 1:22 PMblake77 says:
 Oh my gosh i dont know how you come up with this stuff its genius
Feb 16, 2010. 2:32 PMcb92 says:
Plenty coconuts right outside my window, this is a great idea. It takes a lot of twists to get a coconut off, and this item looks like it could do the job. I have had to pay someone to take them down for me. At my job, they pose a safety hazard, and must be removed. Have a jamb cleat from a sailboat to hold the string tight while you are twisting.
Feb 16, 2010. 7:14 PMcb92 says:
So I guess after you get the hook into the coconut, you spin it to break the stem. They are real strong, not easy to snap just pulling.  I'm going to make one, have always wanted to be able to pick coconuts.
Jan 20, 2010. 10:20 AMspenfisher12 says:
you could use a hot nail to melt the edges so the string wont fray as fast.
Jan 17, 2010. 9:20 AMrimar2000 says:
Very smart!!
Jan 17, 2010. 8:37 AMNinzerbean says:
This is so great because when I would use my wire picker it wold often poke holes in papayas that were hanging close together so I would ruin 3 fruits to get just one. Thanks for a great solution!.
Jan 17, 2010. 8:19 AMLuminousObject says:
This is great. I love all of your PVC instructables.
Jan 16, 2010. 8:08 PMObediah says:
What about a slip connector to hold two pipes together?
Jan 16, 2010. 8:00 PMObediah says:
I love PVC projects and this is a great one.  Have you tried using a heat gun?  I've had success with that with 1/2 inch PVC, I wonder if it woudl work on bigger pipes like this.
Jan 16, 2010. 1:27 AMJayefuu says:
Wow. Another ingenious PVC invention. I like.
Jan 16, 2010. 1:28 AMJayefuu says:
Also any chance of a picture of a papaya tree and you using it?
Jan 16, 2010. 3:44 AMlemonie says:
Neat, I like the simplicity of it.
L
Jan 16, 2010. 12:44 AMDoctor What says:
Picking fruit is a delicate process, and this looks like it would do the job quite nicely.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
341
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
