3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper Art with Google Sketchup
Have you ever wanted to make your own paper art and didn't know how? Or just found the process too difficult from the get go. Well with the Sketchup Unfold Plugin developed by Jim Foltz the process of designing your own paper art is easier then ever.
Why spend all that time and effort manufacturing your model with a 3D printer knowing that it might printout with errors when you can do it cheaply and easily with paper. With a paper design in hand for visualization, moving onto more advanced manufacturing methods would be cost- effective.
So lets get started developing paper art with Google Sketchup.
Visit my blog for other creative ideas!!! OpenHead
Step 1Materials
Materials
Here is what you will need to successfully complete this project.
Software
Download and install a copy of Google Sketchup
Download a copy of the Unfold Plugin
Download a copy of the Buckyball from the 3D Warehouse that we will be unfolding for this project.
Other Materials
Scissors - Something to cut paper with.
Paper - Better to use stiff paper.
Tape - I found that using Scotch tape is easier.
11 comments
Jun 10, 2010. 4:24 AMzombiefire says:
what sketch up version did u use
Apr 28, 2011. 2:30 PMfrisbeechamp1983 says:
he seemed to use, since the file is SketchUp 7
Dec 18, 2010. 12:03 AMMusicman41 says:
I can't find the plugin menu. Is it not in version 8?
Oct 1, 2010. 6:44 AMthe gizmoman says:
Darn My computer (mac mini) doesn't have all the hardware require for google sketchup 8
May 6, 2010. 3:01 PMslick8086 says:
Some already mentioned pepakura for glue tabs, but there is also another sketchup plugin for adding gluetabs (called gluetab.rb BION)
http://github.com/rschenk/Sketchup-Glue-Tab-Plugin/
Mar 9, 2010. 2:01 PMhardlec says:
Openhead:  The link to your blog is busted.  I would like more info on unfolding drawings/making 3-D paper models.
Jan 27, 2009. 5:29 AMTangMu says:
Another way to make sure you have tabs is to import the sketchup file into pepakura designer and unfold there. You can also separate the model out into parts so you can make a model larger than a4....
also google nicepapertoys for a good community of toy builders
Jun 7, 2009. 1:29 PMSxkyilu says:
Yeah, but first you need to save your SketchUp file, then export to KMZ extention which is for Google Earth because Pepakura cannot read SketchUp files.
May 16, 2009. 10:01 PMurill says:
you can use the invisible( frosted) tape
Jan 23, 2009. 1:36 PMjakebuck says:
if you leave make tabs when cutting it out on the sides you want to join, you can use glue to attach the tab under the adjoining surface for a more polished look
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sun2407
I'm an engineer, hobbyist, and practical dreamer. You could say I have an endless amount of interests. It seems everyday I find something new and interesting that captures my mind. I have an "Open Hea...
more »
