I was featured on HackaDay! Link: http://hackaday.com/2011/07/05/paper-craft-claw/
I was featured on Make Blog! Link:http://blog.makezine.com/archive/2011/07/working-three-fingered-paper-claw.html
I made a paper claw a few months ago on instructables, and that design wasn't very good, it was small, it had rubber bands on it so the outside didn't look too great and it couldn't pick stuff up. I knew that I could make it better, the way of how it moved and was put together was not created until then, and I so far haven't seen any claws that use a design like this. This claw is based loosely off that design by that it has the same way how it is held together, every thing else is different and better.
This new design is bigger, it can now pick stuff up,and it uses a different way of making the claw open and close, so there is no external parts except the claw segments. It could also be made to suite to what you need, metal for heavy duty, it being longer to pick up stuff for the disabled, plastic for the cost and strength, or any thing else that is flat that you have laying around!
The first 5 people to make it will win a patch!
The first person to make this will win a 3 month membership!
InfiniTTTy already made it!(he messaged me before every one else)
And the other 4 people to make this will get a patch!
dj-party made it second! Derek Scott Customs made it third! Potatoman1234 made it forth!
Here is the video:
Well, anyways, to the instructable!
Step 1: Supplies
Here are the supplies
  • paper(I used thick cardstock but cardboard should work, i didnt test it out)
  • snippers
  • glue
  • wire (26 gauge is what i used)
  • a regular paperclip(not the small kind)
  • plyers
  • scissors
  • and a tack or pin
Step 2: Print the template
Just print it out on a regular printer
I dont have a picture for this so I just used a picture of the parts glued together
Step 3: Glue it and cut it out!
Unfortunately I didn't have pictures while I did this, so i have the picture of the completed parts
Just glue it onto your thick card stock or cardboard(it should work) and with a scissor or an X-acto knife cut out the outline
For the claw segment, after you glue it on and cut it out, glue two pieces together to make it stronger.
Step 4: Poke the holes
Just with a regular pin poke holes in where the circles are.
Step 5: Strengthen the inner segment parts
The inner segment would be too weak and rip eventually if it is left alone, so I added tape to support it. You only need it on the top area where you poked the holes, I didn't think and put the tape all over on it
And then poke the holes again where they are supposed to be again.
Step 6: Puting together the claw segment
It is hard to explain so hopefully the pictures and captions will help.
If you need any help, comment below and i will help
The wire is approximately 1 inch long
Step 7: Making the inner segment
This is the part that you pull in and out to move the claw.
It is hard to explain, so I tried to document how you do it with the pictures and the captions, if you need any help, comment below and i will make sure to help
Step 8: Puting it all together
Get the inner segment, the outer segment parts, the paperclip, and the tape.
Cut the paperclip to three segments, each one is 3/4 in. long and put it in the upper hole on the claw segments, as in picture 2. Get one of the body segments and fold the little things at the top inward, and put it on like shown in picture 3. Keep on doing it for the other 2 body segments and make sure it looks like picture 4
Get the tape(any tape) and tape around the edges, make sure to not get in the way of the movement of the claw and try to make it look like picture 6
Step 9: You are now done!
Congratulations!
To use it you hold onto the outer segment with one hand and the inner segment in the other hand, bring the inner segment out to close it, bring it in to open it.
If you need any help just comment and I will make sure to assist you
The first 3 people to make this will win a patch!
1-40 of 62Next »
dj-party says: Jul 7, 2011. 5:02 AM
My metallic version XD
dombeef (author) in reply to dj-partyJul 7, 2011. 7:37 AM
Wow! Unfortunately, someone private messaged me that they made it, before you, but I am still going to give you a patch!
Can you post a video? I wonder how it moves so smoothly, how thick is the metal?
Great job!
Derek Scott Customs says: Jul 7, 2011. 10:46 AM
here it is
dombeef (author) in reply to Derek Scott CustomsJul 7, 2011. 10:50 AM
I dont see anything
InfiniTTTy says: Jul 7, 2011. 12:40 PM
I build it! Very cool. I should have used thicker card stock for the inner assembly - it's a little flimsy in my version. Maybe I should have doubled everything up instead of just the claws. I also used paperclips which I think are were a little too think which made everything a little more tricky to build. Pics are here: https://picasaweb.google.com/rick.mccaskill/PaperClaw20 Thanks for the instructable!
dombeef (author) in reply to InfiniTTTyJul 7, 2011. 12:46 PM
Congratulations!
Derek Scott Customs in reply to dombeefJul 7, 2011. 1:38 PM
I guess it didn't upload. Do you have a email I could send it to?
dombeef (author) in reply to Derek Scott CustomsJul 7, 2011. 2:02 PM
Before I do that how about you try again?
Derek Scott Customs in reply to dombeefJul 7, 2011. 3:26 PM
ok
dombeef (author) in reply to Derek Scott CustomsJul 7, 2011. 3:46 PM
You made it!
Potatoman1234 says: Jul 28, 2011. 8:43 AM
I have built one i am going to make mine a portal gub
Potatoman1234 in reply to Potatoman1234Jul 28, 2011. 8:46 AM
opps got to put picture
dombeef (author) in reply to Potatoman1234Jul 28, 2011. 9:21 AM
Wow, good job! The patch is coming up!
And if you finish the portal gun you have to post a picture! :)
radioloris says: Mar 10, 2012. 4:19 AM
I just want you to know that I am going to attempt to make this today with 24 kids, ages 7-14. We'll see how it goes!
Thanks for such good details!
dombeef (author) in reply to radiolorisMar 10, 2012. 6:46 PM
Good luck!
And your welcome!
radioloris in reply to dombeefMar 20, 2012. 9:27 AM
Well, it proved to be too difficult for one 2 hour class period, lol. I ended up finishing them for all the 7-9 year olds, and only doing the middle part for the older kids. I had them specifically look at how they were put together and said I wanted them to think of ways to make their own versions out of different materials or sizes.
I called this their prototype. :)
dombeef (author) in reply to radiolorisMar 20, 2012. 6:24 PM
Did you take pictures? I would love to see how they did!
or_ford98 says: Jan 17, 2012. 3:45 AM
man, i love your blue tape!! :))
dombeef (author) in reply to or_ford98Jan 18, 2012. 2:33 PM
Thanks?
or_ford98 in reply to dombeefJan 19, 2012. 9:14 PM
or_ford98 says: Jan 16, 2012. 10:11 PM
how do you send patches?
You have to be pro, then you get a limited amount of patches to send out.
coolguyxp says: Jan 18, 2012. 7:39 AM
Hi,
I was wondering on the paper claw 2.0, how do you make the claw contract some more so that it can pick up smaller objects?
Rybka30 says: Aug 19, 2011. 2:27 AM
i think you are paperman :D great instructable :D
dombeef (author) in reply to Rybka30Aug 19, 2011. 5:54 AM
Thanks!
evindrews says: Jul 25, 2011. 10:38 AM
Please help! On this step, how did you connect the third piece? I could probably figure it out , but it would use alot of improvising and i'm afraid of messing it up.....
dombeef (author) in reply to evindrewsJul 25, 2011. 10:59 AM
Oh, you are making it, Good luck, you are almost done!
Ok, for the third piece you will have to "wing it", just try to bend the wire so it is tight enough, and push it into the extra hole. It is fine it it is a kinda loose, if it is too tight it wouldn't move very well.
When you are done make sure to post a comment on the first step and I will give you a patch!
thing 2 says: Jul 13, 2011. 9:13 PM
I want to make a long one for sneaking or whatever. I wonder if I could make one that will bend or have a kink in it to pick up stuff easier.
dombeef (author) in reply to thing 2Jul 14, 2011. 7:01 AM
I waas thinking of making one like that for the cardboard contest that is happening right now
thing 2 in reply to dombeefJul 14, 2011. 10:51 AM
Cool.
Propslap says: Jul 12, 2011. 5:18 PM
But will it pick up stuff
Will it blend
dombeef (author) in reply to PropslapJul 12, 2011. 5:56 PM
It can pick stuff up, and I know the youtube channel, it will blend.
pietzeekoe says: Jul 9, 2011. 2:34 PM
Make a portal/gravity gun with it
dombeef (author) in reply to pietzeekoeJul 9, 2011. 3:08 PM
That was the original plan with it, but I made my measurements too small, I might make another instructable with the portal gun, it might be my halloween costume
vishalapr says: Jul 9, 2011. 1:01 PM
The video is brilliant!Well done!
dombeef (author) in reply to vishalaprJul 9, 2011. 1:23 PM
Thanks!
vishalapr in reply to dombeefJul 9, 2011. 1:25 PM
You are welcome!
uberdreww says: Jul 7, 2011. 4:34 PM
if you make the main body like an oval it would almost look like the portal gun
dombeef (author) in reply to uberdrewwJul 7, 2011. 6:38 PM
As I was making the plans a few weeks ago(i was really busy and I forgot about it) I was trying to make this for a replica of the gravity gun from the half life series. If you were to do it you would have to make it like this and then cover it with an oval like cylinder.
cloudifornia says: Jul 7, 2011. 3:15 PM
Very interesting, but how is this used as a kid's toy? I'm older than duct tape and I just don't get it.
1-40 of 62Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
