I was featured on Make Blog! Link:http://blog.makezine.com/archive/2011/07/working-three-fingered-paper-claw.html
I made a paper claw a few months ago on instructables, and that design wasn't very good, it was small, it had rubber bands on it so the outside didn't look too great and it couldn't pick stuff up. I knew that I could make it better, the way of how it moved and was put together was not created until then, and I so far haven't seen any claws that use a design like this. This claw is based loosely off that design by that it has the same way how it is held together, every thing else is different and better.
This new design is bigger, it can now pick stuff up,and it uses a different way of making the claw open and close, so there is no external parts except the claw segments. It could also be made to suite to what you need, metal for heavy duty, it being longer to pick up stuff for the disabled, plastic for the cost and strength, or any thing else that is flat that you have laying around!
The first 5 people to make it will win a patch!
The first person to make this will win a 3 month membership!
InfiniTTTy already made it!(he messaged me before every one else)
And the other 4 people to make this will get a patch!
dj-party made it second! Derek Scott Customs made it third! Potatoman1234 made it forth!
Here is the video:
Well, anyways, to the instructable!
Remove these ads by
Signing UpStep 1: Supplies
- paper(I used thick cardstock but cardboard should work, i didnt test it out)
- snippers
- glue
- wire (26 gauge is what i used)
- a regular paperclip(not the small kind)
- plyers
- scissors
- and a tack or pin
Visit Our Store »
Go Pro Today »
Can you post a video? I wonder how it moves so smoothly, how thick is the metal?
Great job!
And if you finish the portal gun you have to post a picture! :)
Thanks for such good details!
And your welcome!
I called this their prototype. :)
I was wondering on the paper claw 2.0, how do you make the claw contract some more so that it can pick up smaller objects?
Ok, for the third piece you will have to "wing it", just try to bend the wire so it is tight enough, and push it into the extra hole. It is fine it it is a kinda loose, if it is too tight it wouldn't move very well.
When you are done make sure to post a comment on the first step and I will give you a patch!
Will it blend
If it was longer be put over a kids arm so the kid could play and make believe they were a robot, etc
Good job!
And thanks!
"For the claw segment, after you glue it on and cut it out, glue two pieces together to make it stronger."
Cheers!
And yeah, I was thinking that anyone could modify it to their need, if it is metal for it being strong or left over plastic, I am even able to change the claw design if I need to pick up different objects, This is just the basic one
If you make it before anyone else, You will get a 3 month pro membership!
I voted! :)
I was thinking, if I won the Toy Contest I could make plans so I could make it better and stronger in plastic. It would also be able to be scaled up and down easier. But it is very unlikely, other instructables are way higher in views and ratings, and some one even made a 3d plotter out of legos!
