loading
loading
Picture of Paper Claw 2.0
I was featured on HackaDay! Link: http://hackaday.com/2011/07/05/paper-craft-claw/
I was featured on Make Blog! Link:http://blog.makezine.com/archive/2011/07/working-three-fingered-paper-claw.html
I made a paper claw a few months ago on instructables, and that design wasn't very good, it was small, it had rubber bands on it so the outside didn't look too great and it couldn't pick stuff up. I knew that I could make it better, the way of how it moved and was put together was not created until then, and I so far haven't seen any claws that use a design like this. This claw is based loosely off that design by that it has the same way how it is held together, every thing else is different and better.
This new design is bigger, it can now pick stuff up,and it uses a different way of making the claw open and close, so there is no external parts except the claw segments. It could also be made to suite to what you need, metal for heavy duty, it being longer to pick up stuff for the disabled, plastic for the cost and strength, or any thing else that is flat that you have laying around!
The first 5 people to make it will win a patch!
The first person to make this will win a 3 month membership!
InfiniTTTy already made it!(he messaged me before every one else)
And the other 4 people to make this will get a patch!
dj-party made it second! Derek Scott Customs made it third! Potatoman1234 made it forth!
Here is the video:
Well, anyways, to the instructable!
Step 1: Supplies
Picture of Supplies
Here are the supplies
  • paper(I used thick cardstock but cardboard should work, i didnt test it out)
  • snippers
  • glue
  • wire (26 gauge is what i used)
  • a regular paperclip(not the small kind)
  • plyers
  • scissors
  • and a tack or pin
Step 2: Print the template
Picture of Print the template
Just print it out on a regular printer
I dont have a picture for this so I just used a picture of the parts glued together
1-40 of 64Next »
I have built one i am going to make mine a portal gub
opps got to put picture
dombeef (author)  Potatoman12343 years ago
Wow, good job! The patch is coming up!
And if you finish the portal gun you have to post a picture! :)
here it is
dombeef (author)  Derek Scott Customs3 years ago
I dont see anything
I guess it didn't upload. Do you have a email I could send it to?
Before I do that how about you try again?
ok
You made it!
InfiniTTTy3 years ago
I build it! Very cool. I should have used thicker card stock for the inner assembly - it's a little flimsy in my version. Maybe I should have doubled everything up instead of just the claws. I also used paperclips which I think are were a little too think which made everything a little more tricky to build. Pics are here: https://picasaweb.google.com/rick.mccaskill/PaperClaw20 Thanks for the instructable!
dombeef (author)  InfiniTTTy3 years ago
Congratulations!
dj-party3 years ago
My metallic version XD
dombeef (author)  dj-party3 years ago
Wow! Unfortunately, someone private messaged me that they made it, before you, but I am still going to give you a patch!
Can you post a video? I wonder how it moves so smoothly, how thick is the metal?
Great job!
MMSSS1 made it!5 months ago
i make it
it is easy but I got Simple difficulties
i love it
i will make it again by steel if anyone can help me to make it by steel
jackmaster8 months ago
this is bad ass!!
radioloris3 years ago
I just want you to know that I am going to attempt to make this today with 24 kids, ages 7-14. We'll see how it goes!
Thanks for such good details!
dombeef (author)  radioloris3 years ago
Good luck!
And your welcome!
Well, it proved to be too difficult for one 2 hour class period, lol. I ended up finishing them for all the 7-9 year olds, and only doing the middle part for the older kids. I had them specifically look at how they were put together and said I wanted them to think of ways to make their own versions out of different materials or sizes.
I called this their prototype. :)
Did you take pictures? I would love to see how they did!
or_ford983 years ago
man, i love your blue tape!! :))
dombeef (author)  or_ford983 years ago
Thanks?
how do you send patches?
You have to be pro, then you get a limited amount of patches to send out.
coolguyxp3 years ago
Hi,
I was wondering on the paper claw 2.0, how do you make the claw contract some more so that it can pick up smaller objects?
Rybka303 years ago
i think you are paperman :D great instructable :D
dombeef (author)  Rybka303 years ago
Thanks!
evindrews3 years ago
Please help! On this step, how did you connect the third piece? I could probably figure it out , but it would use alot of improvising and i'm afraid of messing it up.....
dombeef (author)  evindrews3 years ago
Oh, you are making it, Good luck, you are almost done!
Ok, for the third piece you will have to "wing it", just try to bend the wire so it is tight enough, and push it into the extra hole. It is fine it it is a kinda loose, if it is too tight it wouldn't move very well.
When you are done make sure to post a comment on the first step and I will give you a patch!
thing 23 years ago
I want to make a long one for sneaking or whatever. I wonder if I could make one that will bend or have a kink in it to pick up stuff easier.
dombeef (author)  thing 23 years ago
I waas thinking of making one like that for the cardboard contest that is happening right now
thing 2 dombeef3 years ago
Cool.
Propslap3 years ago
But will it pick up stuff
Will it blend
dombeef (author)  Propslap3 years ago
It can pick stuff up, and I know the youtube channel, it will blend.
pietzeekoe3 years ago
Make a portal/gravity gun with it
dombeef (author)  pietzeekoe3 years ago
That was the original plan with it, but I made my measurements too small, I might make another instructable with the portal gun, it might be my halloween costume
vishalapr3 years ago
The video is brilliant!Well done!
dombeef (author)  vishalapr3 years ago
Thanks!
You are welcome!
uberdreww3 years ago
if you make the main body like an oval it would almost look like the portal gun
1-40 of 64Next »
