3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paperclay Recipe (Air Dry Clay)
Intro: Paperclay Recipe (Air Dry Clay)
Paper and clay on their own lack strength. But when they are put together in this air-dry paper clay recipe, you can do amazing things. (Even artificial bones!)
What is so great is that it requires few items to make this air-dry clay, cost hardly anything and recycles waste paper.
It is easier to model than clay on its own and dries fairly quickly. You can sculpt thinner and use an armature for support you can let your creativity free. (Its also possibleto attach pieces of different drying stages though keep the additional pieces covered to dry slowly to prevent cracking.) And another advantage is single firings with glaze on greenware or leaving completely unfired works its now possible to save time and money.
Watch the one minute run-down of this instructable here
Step 1Things you Need for Air-Dry Paper Clay
Paper (newspaper or office paper)
Hydrated Lime
Clay (stoneware looks so pristine, but terracotta will fire at lower temperatures)
Optional: About sodium silicate "Magic Water" to join coils and fix cracks (a low temperature fire may be sufficient)
Fine mesh fabric such as muslin
Buckets
The clay can be dug up from your backyard or bought rock and debris free. I chose the latter type of clay to use.
There's a simple method of preparing your own dug up clays that I found interesting. (Watch the master potters of San Marcos here!)
9 comments
Jan 31, 2011. 3:44 PMgserrano701 says:
I like it very much. I've done papier mache in the past but never thought about mixing it with clay, will try.
Jan 17, 2011. 8:04 PMacexkeikai says:
could you do the same think with air drying clay? to make air drying paper clay?
Jan 18, 2011. 5:03 AMacexkeikai says:
I also saw a method that used toilet paper (not used LOL) and it makes a finer pulp... cheap brands can be used I think they also used the roll in the mix.
Jan 18, 2011. 5:00 AMacexkeikai says:
Oh good! I didn;t know it was air drying clay :) I should try and make some then since I can't find Paperclay in my area :) How long does paperclay last? since it's got paper it can get moldy.
Jan 18, 2011. 3:53 PMacexkeikai says:
I know cold porcelain people use vinegar... Nutmeg oil must smell much nicer though... i should try and find some thanks :)
Jan 7, 2011. 11:33 AMCulturespy says:
This is really great. I think a main image with some objects you've made with the paper clay would help inspire people to make their own!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:Gomi Romi
