iImage Information
This is a simple instructable...nothing special, just useful and cool looking. There really is only one step to make this instructable, so its short and sweet.
Step 1Bend the Clip
iImage Information
The paper clip is a simple device invented by Erlman J. Wright in 1877 and has remained unchanged ever since. It is a staple (no pun intended) device of the office and now can be used in more ways than to just hold pages together.
Basically, the clip has a smaller loop and a larger loop. To make the tack, simple bend the straight wire of the longer loop 90 degrees towards you (if the paper clip is laying on the desk)
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
http://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
