Introduction: How to Make a Paper Corsage
Okay guys, nothing will make a girl feel special like a beautiful corsage to wear out to that fancy dinner you're planning for her for Valentine's Day. The problem is, flowers die! So here's a corsage that you can make for her that will last forever!
Step 1: Gather Supplies
Template : the template for this project can be downloaded from the Canon website here
The instructions can also be downloaded there, but I found them rather lacking. So that's why I decided to put this instructable together.
Glue: I used both a glue stick (not pictured) and Aleene's Tacky Glue
(I find Tacky Glue much easier to use if I pour some in a plastic tray and use a toothpick to spread it)
Scissors: you can use a pair of regular scissors, but you might also like to use a pair of shorter detail scissors, like those pictured.
Stylus
Ruler
Stylus
Ruler
Step 2: Cut Out the Petals
Cut out the rectangles surrounding each petal piece, along the solid lines. You really don't need to worry about the part numbers!
Step 3: Glue and Fold Petal Pieces
Using the stylus and ruler, score along the dashed line on each petal piece and fold. Open and spread glue along one half. I used a glue stick for this because it won't warp the paper and it dries quickly.
Step 4: Cut Out Each Petal
Cut out the petal shape from each piece. Also cut a slit along the red line separating the numbered tabs.
Step 5: Score and Fold Tabs
Score and fold along the dashed line of each numbered tab.
Step 6: Glue Tabs Together
The lowest numbers on the tabs correspond to the part numbers on the Canon instructions. So, for example, the petal piece with tabs numbered 5 and 6 is Part #5 in the instructions. In order to help keep things straight I glued them so that the lowest numbered tab was on the outside. Apply Tacky Glue to the highest numbered tab and fold the other tab on top of it.
Step 7: Curl Petals
Using the stylus as a guide, curl the petals as stated below:
On Part #5 curl both edges of the petal inward with one overlapping the other
On Part #6 and Part #7 curl both edges of the petals loosely inward
On Parts #8 - 14 curl both edges of the petals outward
Step 8: Make Rose Center
Apply glue to the bottom of Part #5 and press it on top of Part #6, wrapping the edges of Part #6 around Part #5. Put glue on the bottom of Part #6 and glue it inside Part #7 in the same way. You should now have a rose center, with one petal wrapped tightly between two other petals.
Step 9: Adhere Outer Petals
Apply glue to the bottom of the rose center and adhere to Part #8. Continue to apply the rest of the petals (Parts #9-14) in the same way, overlapping the petals slightly. It may seem like they don't fit together very well, but trust me, it will come out looking okay! Paper is very forgiving!
Step 10: Make Other Two Roses
Repeat steps 2-9 for the yellow and blue roses.
Step 11: Cut Out and Assemble the Base (Part #2)
Score and fold along the dashed lines, opening it back up after each fold.
There are two #2 tabs; apply glue to the white area of one of the tabs and fold the other one over it.
Apply glue to the white area of the #2 tab that is now on top and fold the remaining tab down on top of it.
Note - this will be a three dimensional pop-up pyramid type piece. It is not supposed to be flat, so don't squish it down!
Step 12: Adhere Roses to Base
Glue the roses to the white areas of the base piece. I found it helpful to use my stylus to press the base to the flower from inside the base.
Step 13: Cut Out and Adhere Leaves
Cut out the larger rectangle surrounding the leaves. Fold it in half and glue it just like you did the petal pieces, then cut out the leaves. Adhere the leaves to the base. You can shape the leaves a bit by bending them back, if desired.
As you can see in the picture, I also glued a ribbon bow to the back of the leaves. I thought this would make it easier to pin it on as a corsage.
