Paper Lamp for Diwali
999
24
9
Published
Introduction: Paper Lamp for Diwali
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
It is Diwali time in India, festival of lights. I make a lamp every year to celebrate Diwali and decorate my house.
This design is based on Paper-Lamp-cathedral-Light by EzyCraft, beautiful and attractive lamps from paper
Differences
  • I am not using A4 Size paper, So that to modify it to best fit for the sheet size available for me locally
  • Optimized Support system
  • Super glue not used as I always end up sticking myself
Also I wanted kids to be able to make it under adult supervision
Step 1: What Do We Need ?
Material
  • A1 size cartridge paper
  • Cutting Mat
  • PVA Glue / Fevicol
  • Glue stick
  • Steel scale
  • Paper cutter
  • Scissors
  • String lights
Step 2: Template
The cartridge sheet I got was smaller than A1. So that to come up with different template solution to get 9 sheets out from the sheet available. Details of the templates shown in the images. Template is not to scale, one needs to hand draw it.
Step 3: Cutting
  • Cut three strips at 171 MM height or width along the long side of the sheet
  • On plain A4 sheet, draw and cut based on template
  • Using the above as master cut rhombus as shown in pictures
Step 4: Assembly
  • We have 3 cuts at
    • 83 MM : Interlock within same sheet
    • 53 MM : Interlock with the next sheet ( N )
    • 24 MM : Interlock with N + 1
  • It makes a design as shown with 9 sheets and then connect the first and last sheet to make a circle
  • Place a bottle is between to give shape and support while we work
  • Using glue stick, stick the outermost edges
Using a bottle really helped
Step 5: Supporting
  • Cut 1 strip : 235 mm and stick it to overlap 5 mm as shown
  • Cut a 8 circles with diameter 74mm
  • Stick all the circle pieces together and cut a small opening to pass "string light plug "
  • Glue the stip and circle using PVA glue or fevicol as shown
  • Leave it to dry for 1 hr
Step 6: Electrical
I used old rice bulb string light with 120 bulbs.
Tie it in a bundle that is smaller and compresses inside the lamp as shown
May have to add a guide circle to center the lights
Step 7: Hang It
The string lights are strong enough to bear it's and the paper lamp's weight or Using a string hang from the ceiling
Test the lamp with different color string lights
Please share your comments
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
    9 Comments
    Super nice version of a paper lamp! One of the prettiest I've seen!
    This is amazing! I would have never guessed it was made from paper!
    There are a lot of designs in paper lamps...
    That's a beautiful design! This would be really neat to do with different colors too. :)
