Paper Marbling With Food Dye and Shaving Cream
3,461
197
6
Published
Introduction: Paper Marbling With Food Dye and Shaving Cream
About: Just a girl who spends her days crafting! I love creating new things out of duct tape, clay, or anything that can be made into something new!
A quick and easy way to marble paper!
Step 1:
Step 2:
~ Supplies ~
~ Ruler
~ Food Dye
~ Shaving Cream (make sure it is foam)
~ Painters Tape
~ Envelopes/ Paper
~ Plates
~ Tooth Picks or Spatula
~ Tray
Step 3:
Start by taping off any areas of the paper you do not want to be marbled. Since I started by marbling the flap of the envelope, I also used a different piece of paper to help cover up the area I wasn't marbling.
Step 4:
Cover the tray in a layer of shaving cream. Then, add a few drops of food dye onto the shaving cream. Next, take the spatula or the tooth pick and mix the food dye with the shaving cream. I use the tooth pick when I want to create more of a pattern. Using the spatula will create more of the marbled look.
Step 5:
Next, press the paper on top of the shaving cream. Then, pull up the paper and take the rule and scrape the shaving cream off. Let dry before using.
Dyeing for Color Contest
Third Prize in the
  • Backpack Challenge
    Backpack Challenge
  • Stick It! Contest
    Stick It! Contest
  • BBQ Showdown Challenge
6 Discussions
In second grade my science teacher used the wrong kind of shaving cream,it did not work.in conclusion Always use foamy stuff
Wow! I didn't know you could use regular paper & food dye for this! Thanks!
It's spectacular on glossy or photo paper.
Thank you! I'll have to try it on the glossy paper! I've also seen where people use the same technique on fabric.
I just have to try this for our next charity card event. thanks so much for sharing.
I can't wait to give it a try, thanks for sharing :-)
I love this idea and it's numerous other applications. I'll have to see if I can add it to my growing list of things to try. :)
