Paper Nerf Blowgun(P.N.B)
Published
Introduction: Paper Nerf Blowgun(P.N.B)
About: I like to make knex guns, swords, and medieval artillery, I sometimes draw, play music, and Mod nerf guns.
Hi! I'm back with a paper nerf blowgun That I made.
Pros
Dart holder(can make more if you want)
Easy to make
Can fire Elite darts, stephans, micros, paper darts of the correct size.
DIY
Silent(not completely but mostly)
Cons
Bad range (18-20 ft angled)
Overall, It's OK, if you are not 1-20 ft from your target, you won't hit unless you have like a pressurized air tank attached to it lol
Step 1: Darts
Darts are obviously modified, Cut them with scissors until they are an inch long.
Step 2: Gun and Dart Holder
Roll up a full sheet of paper, then cut to where it is just over 8 inches long, the use the cut off piece and wrap it around a dart then cut until you can see the bottom of the dart in good light, then tape the dart holder to the front of the barrel. Then, on the back where you blow through, tape around there so it doesn't fall apart
Step 3: Done!
Now load through the front, And blow from the back!
    • Game Life Contest
      Game Life Contest
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
