3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper Nunchakus
Paper Nunchakus
Nunchakus to practice with. They still hurt but they aren't anything serious. Its not my fault if you injure or kill yourself or someone else with these. Please have common sense.
made from-
2 magazines without thick spines (i used Boys Life)
duct tape
3 feet of nylon rope or twine
Step 1Preparing the Magazines
You need 2 magazines, preferably both with around 50 pages. the magazines need to not have thick spines. it works best if the pages are just stapled together at the end instead of glued next to each other.
Roll up a magazine as tight as you can, but leave enough of a hole in the middle that you could slip a small rope into the inside. hold it upright and make the edges even by placing the bottom on a table, and pushing down on the top. once it is even tape the sides on the top and bottom to get it to hold its position.
Repeat.
12 comments
Mar 27, 2010. 2:32 PMApple_4_life says:
These are great! a way to make a mini pear is to cut 1 magazine in half then use that as your handles and they are more pocketable :)
Mar 14, 2010. 9:02 AMClaudiaRN says:
 Once upon a time We studied martial arts,  and ended up making some out of the insulation foam that goes around pipes. LOL not heavy but the kids didn’t hurt each other!
Dec 23, 2008. 3:05 PMregipalka says:
I like the idea but the rope kept coming out
Apr 28, 2009. 1:35 PMtanis9319 says:
try useing longer rope and tape it to the out side of the chuck
Feb 10, 2009. 3:33 PMclemsonguy1125 says:
hot glue th know ends to the engof the magazine of even use epoxy glove
Dec 31, 2008. 5:30 AMregipalka says:
i figured out how to keep the rope i. u have to put the rope through like normal then thred it through again then tie it. it also makes a grip
Apr 7, 2009. 7:34 PMSergant Tinkers says:
Awesome!
Jan 18, 2009. 9:35 PMlobo_pal says:
You can make those out of rope alone, and they will be heavier for better hits.
Jan 13, 2009. 4:28 AMmowie says:
i used nun's life
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:imthereal
