Paper Organizer(Talon Stand)
Published
Introduction: Paper Organizer(Talon Stand)
Organize your troubles away
Step 1: Gather Materials
Step 2: Measure Out the Wood
Take 1 of the 1 x 4 x 8 pieces of wood, a yardstick, and measure out 12 inches on the wood.
Measure out 4 pieces of 12 inches
From the 1 x 4 x 8 measure out 18 inches. Measure out 4 of them
Measure out the ply wood
4 9 x 13
1 14 x 18
Step 3: Marking the Wood
Mark the 12 inch on the wood, with 4 inches in between each
and do that to both pieces
Then cut out the ply wood to the pieces measured above
Step 4: The Bolting
Take the marks that you made on the long sides and then mark 2 dots along the horizontal way and make the holes with the drill and then place the nails in and add the bolt. Repeat on all 4 pieces of long wood
Step 5: Assembling
Once the bolts are in, you then begin to build it.
Hold the 2 long pieces together and you are going to drill in a hole so that the two columns can stay stable when upright.
Then add the two bullets and then place the piece that will connect them
do the same to the other side.
Then place the top on, and drill that together.
Step 6: Final Assembling
Once the wood is assembled, you can then place the ply wood in to complete the shelving
Step 7:
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
