Step 2: Print & Cut Template
I have attached a pdf drawing with all necessary measurements to use as a guide or as a template for making paper pockets. Depending on how many you plan on making, you may either print directly onto the paper you want to make your pocket from, or create a reusable to trace onto any card weight paper.
Use the cutting mat and X-acto knife to cut your template. The metal ruler is a useful straight edge if you are not comfortable cutting free hand.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
