Paper Resistor
Paper Resistor
A simple technique to make a variable resistor from paper and pencil.
Step 1List of materials required:
All the things required to make this resistor are readily available in homes and
you will not require to spend any money to buy them.
The materials required are as follows:
(1) A thick (rather stiff) sheet of paper.
(2) A HB pencil.(preferably 3B,4B or 6B)
(3) A ruler or scale.
(4) Few metal paper clips.(will be used as the pins of the resistor)
(5) A multimeter or ohm meter to measure the resistance and calibrate your
resistor.
(6) pair of scissors.
16 comments
Jan 29, 2010. 6:23 AMraju1192 says:
Actually my question is how to connect with Multimeter?
and it will not get heated?
plz answer me.
Jan 17, 2010. 9:31 PMamit13121991 says:
does anything happen 2 the paper due 2 the heat generated by the resistor.....
Nov 14, 2008. 12:10 PMjrt42 says:
How about a strip of foil on paper?
Nov 26, 2009. 9:23 PMLkArio says:
The resistance would be very low, much less than a quarter of an ohm
Dec 26, 2008. 10:17 AMjoinaqd says:
hi i really liked your instructable because its so simple...someone once told me to make resistor out of pencil lead but its hard...your idea is so simple and easy...i hav a question..Can i use this to charge my 6 volt battery using a 12 volt charger if i use the resistor?please answer back.
Sep 6, 2008. 4:32 PMsonic1234 says:
what does it do
Oct 16, 2007. 9:39 AMkishcool2005 says:
It is a good idea buddy...but when days go on ,the resistance value will decrease gradually due to removal of carbon particles from the paper...any how you have given an alternative for resistor...gr8 job..!
May 3, 2007. 12:06 AMAbizer says:
very cool.i tried the same project yestrdy . it works
May 1, 2007. 4:46 AMa_d777 says:
very cool thing... i just tried it... i could not find any paper to 'sketch' it on... i took a small calendar and sketched it on that... what wonderful results i got!!! my variable resistor varies from 90k to 1800k... below is a picture of it!
Apr 29, 2007. 9:20 AMlemonie says:
What practical range (Ohm) can you get out of this, and how much current will it take?
Apr 30, 2007. 1:06 PMmje says:
I think what he's asking is really how much power it can handle. I suspect the answer has to be empirically determined.
Apr 30, 2007. 2:34 PMlemonie says:
Yes, correct on both counts. L
Apr 29, 2007. 4:21 PMKiteman says:
You can make a variable resistor directly from the pencil:
Using your Instructables Leatherman (ahem), slit the pencil length-wise. If you're careful, you can split it cleanly along the glue, otherwise you may need to whittle a little wood to expose the "lead" (yes, I know it's graphite) along the full length of the pencil.
Then just clip on wherever you need to.
I like this idea though - I may pinch it to allow my pupils to keep something "real" in their exercise books.
Apr 29, 2007. 9:56 AMBrennn10 says:
Very cool indeed.
Apr 29, 2007. 8:26 AMSgt.Waffles says:
I remember doing this before. Its a pretty cool DIY, and could help to teach youngn's about electronic stuff.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:science4u
I am a student at BITS-Pilani,Goa Campus.
