I found the solution to the expense in a makezine podcast. It features a compressed air rocket launcher, using PVC pipe with an electric irrigation valve, and a standard bike pump. The same assembly is featured in Make: Vol 15.
I recently put this launcher kit together. It was very easy and took me maybe 30 minutes. Assembling the launcher is very well documented in many places (including the kit instructions).
This instructable focusses on assembling the rockets. The kit has ok instructions but I found the templates, and techniques described produce a rocket that's good for maybe 6 launches before the rocket becomes so maimed that one has to build another.
My own template (developed based upon the original) improves upon the "design" and construction techniques to produce a rocket that can take 10 or 15 launches worth of punishment before becoming a crumpled wad of tape and paper.
Remove these ads by
Signing UpStep 1Gather Your Materials.
1. 2" wide painter's tape.
2. flexible measuring tape.
3. untreated facial tissue (the rough, hurt your nose kind), or toilet tissue.
4. modeling knife.
5. straight edges.
6. Q-tip.
7. Launch Tube Blank.
8. paper template.
I really like your measured work surface; must be durable for one to cut on, eh?
It would be epic if you would advise of product name and/or source.
Cheers!
The launcher is available at the Maker Shed Store. Follow the link I've placed in the intro step.
The rocket template that I use is attached. It is annotated and is pretty self explanatory when coupled with this instructable.
Enjoy!
