3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper Wall Lamp
Paper Wall Lamp
I've been knocking this idea around in my head to make these wall-mountable light boxes, but I guess I needed a boring summer to convince to me do it. With these materials, it actually makes two sets of three or you could make a long six light set. I wanted to make a lamp with a soft glow as well as a wall fixture that is attractive even when the light is off. This is a very easy design with simple, everyday materials. I used what I had laying around the house but this could definitely be made with more sturdy materials.
Step 1Materials
Materials
1. Paper ( I used sketchbook paper because it was sturdy and it let enough light through. Rice paper or maybe natural fiber paper would also look good here.)
-sketchbook paper (18 x 12) 10 sheets
-one piece of black core foamboard (30 x 20)
2. Lights (I had two sets of white led rope lights about 9 or 10 ft. long left over from a xmas sale. As far as lights go here, you can use what you want but they need to have low watts because of the obvious fire hazard.)
- two sets of led rope lights
3. Tools
-Box cutter
-stapler
-scissors
-glue (Elmer's is fine)
-mounting screws and wire
-pencil
-measuring tape
-hot glue gun or household cement (for gluing the foamboard)
-plastic zip ties
23 comments
Jan 3, 2012. 4:31 AMdreadyjazz says:
Love it!
Jan 13, 2010. 12:42 AMsushantech says:
please add video to know better
Jan 4, 2010. 1:58 PMdiygirl says:
Very cool.
Dec 3, 2009. 9:48 PMkknudson93 says:
Totally atractive. Something I'd show or make my friends ;) Thanks!
Sep 16, 2009. 5:35 PMGabey_Chow says:
that looks absolutely beautiful mann... great job!!
Feb 20, 2009. 8:57 AMRonBot says:
I've seen luminaries in old magazines made from varnished paper bags. If you coat paper with clear Varithane- they have water based now- will the paper be sturdier? Safe? What about using canvas,muslin, or cotton duck instead of paper?
Jan 29, 2009. 1:28 PMNitocris says:
Yes, I must make this immediately..it's adorable and doesn't seem overly bright, so it's great for an accent piece. Also, plus side.. I have most of the materials already, heh! Great work on this. :D
Dec 2, 2008. 2:07 AMmeme_mhr says:
Love the idea
Aug 22, 2008. 8:51 PMhrdhead27 says:
i love it but i will have to try to make the light boxes a little less complicated. i might also use a single led light, i'm not sure how exactly, instead of all the tubing from the rope lights. i love foam core and this is a brilliant use for it.
Jul 16, 2008. 8:53 PMtooabstract788 says:
This is really awesome. It would look really great if took some wood and made a frame for for the paper, that way it had a japanese style to it. Kind of like a shoiji lamp you know? When I get around to making this, I'll make it with frames anf show you a pic of it. Great idea.
Aug 22, 2008. 7:37 PMjillg says:
and you could use Japanese print or characters on t3h paper
Jun 20, 2008. 11:39 AMfiregardeneve says:
this is great!
Mar 23, 2008. 1:08 PMMr. Rig It says:
Would love to see you add this to my new group.
Hope to see you there.
Home Repair, Refurbishment, and New Projects
Sep 13, 2007. 11:12 AMdouro20 says:
I have an idea; you could lacquer some stiff paper and make one which can take regular incandescent lights (15W or smaller).
Jul 31, 2007. 7:14 PMhay_jumper says:
What will you do when Donald Judd's lawyers come a-callin?
Aug 2, 2007. 10:38 PMwhiteoakart says:
This is way to complicated for Donald Judd. Most significantly, it has a function as a lamp. This is the conceptual antithesis of Donald Judd, even if it does superficially look like some of his sculptures.
Aug 2, 2007. 10:47 PMhay_jumper says:
Whoops! I forgot to add the following tags: Take it easy there, fella.
Aug 2, 2007. 4:17 PMbuZztiaan says:
Won't this get very very very hot?
Aug 2, 2007. 5:09 PMLaminar says:
Naedhi uses LED rope lights, so no. Low wattage compact fluorescents would work nicely too.
Jul 31, 2007. 1:07 PMcrapflinger says:
if you were to use wood instead of foam core you could make this into a bookshelf/lamp conglomoration
Jul 31, 2007. 8:12 PMWard_Nox says:
thats a good idea
Jul 31, 2007. 5:28 AMKiteman says:
This is a very stylish lamp, quite 80s retro (so it won't go in my house!). If you had a ready supply of lights to go inside you could almost go into production!
One small niggle: the rope light is hanging out of the bottom - wouldn't end-pieces to the foamboard box make it much tidier?
One large niggle: step two is very confusing. I worked it out from the photos, but the text wasn't much help. That step need a re-write, especially when you consider how many members have English as a second language.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:naedhi
