Paper Wallet
Step 7Zipper Folding
Zipper Folding
I finally figured out an easy way to explain this
you will lock both ends separately.
starting from the inside, and going to the outside, there will be a flap, then a pocket, then another flap, and another pocket. We'll call these 1,2,3,4 respectively. Fold the inner flap (3) into the inner pocket (2), then fold the outer flap (1) over 2 and 3, and into the outer pocket (4).
do the same to the other end.
i would suggest taping flap 3 inside the pocket to hold the wallet together better.
23 comments
Jul 28, 2011. 5:00 PMayeo99 says:
Dangermarc : Thanks a million for the explanation and the picture.
Now I got it!
Jul 27, 2011. 12:36 AMLangarulz says:
I give up too confusing :(
Nov 2, 2010. 5:02 PMMrCreator says:
I love this instructible! Once I made one, the process seemeed MUCH easier! Just make one of copy paper, then use something durible, like construction paper. Mine turn out a little odd, and you all might have odd ones too, but if you cut at the right places and sizes, it makes it work. :D
Oct 15, 2010. 11:14 AMzachary32 says:
and on steps 6 and 7 theres a way to interlock both sides ill try to post a picture of it
Oct 15, 2010. 11:13 AMzachary32 says:
i did this wallet and it is great but i made mine with taped together monopoly money and then put clear tape all around it and made it waterproof i was gonna do a different one but then it was to hard so then i had a big sheet of monopoly money so then i used this design but it works very good for me and since mine has tape all over it its waterproof and it has lasted me about 3 months now.very very good design
Jul 29, 2010. 11:26 PMreefhugger says:
love love love this instructable!! i got confused on this step because i didnt get that each side was a 1,2,3,4 series, i had the wallet folded up and couldnt understand the order of flaps and pockets. if you take the directions for each side, it was super easy! thanks!!!
Apr 3, 2010. 8:41 PMcatfish23 says:
 Sorry, I can't spell!
Apr 3, 2010. 8:40 PMcatfish23 says:
 This was great! The "zipper" folding is enginious!
Mar 22, 2010. 10:29 PMmcgyver0012 says:
once you get to here it should be really easy and thanks to him my wallet is great!
Apr 27, 2007. 8:09 PMinstructa-fan says:
making it a little easier, fold the outer flap to the hole on the inner one, and the inner one on the hole in the outer one.
Feb 11, 2010. 12:02 PMallhailluis says:
thanks this cleared things up
Aug 4, 2008. 2:15 AMbondini says:
gr8 step helped me a lot props thnks
May 6, 2007. 5:16 PMbooga1134 says:
thanks instructa!
Nov 1, 2008. 9:49 AMaa985 says:
hi u noe i have trouble with this mostly step 7 it was hard i actually threw the paper because it was a ll confusing can u make it easier???
Nov 24, 2009. 3:52 PMmizzoufan96 says:
HOW could this be confusing
My 5 year old brother asked what i was doing and made one all by himself!
Nov 2, 2010. 5:04 PMMrCreator says:
lol i think it's easy enough
Sep 30, 2009. 2:22 PMd22 says:
i cant make it
Sep 4, 2009. 7:51 PMrunrun265 says:
I needed a clear pocket on the inside for my bus pass so i took syran wrap and taped it in. working quite nicely
May 15, 2009. 3:32 PMcccdub says:
this makes no sence to me at all...
Aug 4, 2008. 2:08 AMbondini says:
thanks 4 that i just made a prototype from lined paper in 5 mins... now onto bigger and better things (its time to CUSTOMIZE!) props 2 ya 4 the gr8 design
Mar 3, 2008. 10:42 AMdangermarc says:
I figured out that the confusion here, for me, was in the folding. If you fold it right, the zipper fold is easy to understand. Fold the paper inwards in the order shown here: 1) Top crease 2) Bottom Crease 3) Middle crease
Mar 4, 2008. 3:38 PMdnutman says:
Thanks- this is the part that I kept having trouble on.
Jun 21, 2007. 4:34 PMfadbum says:
that was cool
May 17, 2007. 1:09 PMgomerbarkley says:
Thanks for the good instructions. I did it while bored at work (don't tell, 'k?!).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:theRIAA
