3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper cup hydro electric generator
ok so when submitting my water pump instructable i saw the competion for paper coffee cups, this gave me some ideas but the closing date is the 9th, today is the 9th (at 2.26am) so i dont have time to get hold of a bunch of paper coffee cups and i dont think it would be in the spirt of the thing just to get a load and waste them. so i have done some diagrams to demostrate my idea.
its the basic water wheel system based on the Haris design of wheel used in hydro electric dams.
Step 1Starts with a bicycle wheel
ok so you take a basic Bicycle wheel a mountain bike one would be ideal as the channel is wider where the inner tube goes, also would be better to use a larger wheel say 26" or more but it will have to be steel so you can weld it.
you need to weld the spindel to the main wheel so when it spins it spins the wheel with it not just the spindel on its own, you could take this out and replace it with a long rod which will go off to our generator.
20 comments
Jun 10, 2010. 11:12 PMjimmerforpoy says:
how much power does this generate?
May 17, 2010. 4:25 PMHoudinipeter says:
 Could you do this with a small alternator so this could be very cheap?
like this
or this?
May 18, 2010. 2:32 PMHoudinipeter says:
 because this concept design would be even better if it was super cost effective and could be easily invested in by people with gutters.
May 18, 2010. 5:03 PMHoudinipeter says:
 I assumed an old car alternator costs money.. And it needs to be pretty i guess..  Just thinking out the idea. Need to fail to succeed.
May 9, 2010. 4:40 AMKiteman says:
Coffee cups do eventually go mushy - I would varnish these to prevent that happening, or use plastic coffee cups instead.
May 9, 2010. 8:30 PMsfcsarah says:
Yes, that's a serious problem, since I don't think it would last more than a few minutes unless it was waterproofed somehow.
It's an interesting idea though.
May 12, 2010. 2:40 AMKiteman says:
If you've ever left a McD cup to stand too long, you'll know they eventually leak, and the waxy stuff is only on the inside anyway.
May 9, 2010. 6:51 AMKiteman says:
I realise that, hence the first comment about varnish.
May 10, 2010. 7:23 AMlocaltalent says:
 I think the weight of the water will eventually break the glue bond - you'd be better off with mechanical attachment, like if you put the spoke through the cup and washers around the spoke nipples.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:n1cod3mus(Chris Fry Design)
I'm a web developer, IT engineer, Graphic Designer. I have a creative nature and an over reactive imagination which is perfect for instructables.
