3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper Airplane Walkalong Glider
What's a walkalong glider? Here's a video of a completed paper airplane walkalong glider on a 42 second "cross country" soaring flight:
This paper airplane design was fabricated from 100% reused materials, from the 8 1/2 X 11 sheet of paper to the 96cm X 75cm corrugated cardboard salvaged from the trash. this is a good way of reusing paper and cardboard before ultimately recycling them. Ever wanted to pilot an airplane? Here's a way to do it without electricity or contributing to global warming- this aircraft model is powered by you.
The surfer paper airplane is designed to fly as a walkalong glider. Paper airplanes are heavier than other walkalong glider designs and fly correspondingly faster. A 96cm X 75cm piece of corrugated cardboard was used as a controllable slope to power (sustain) and control the surfer paper airplane. For other walkalong glider designs see the Controllable Slope Soaring page.
The Indoor Paper Airplane Surfer has many improvements over this design. That didn't stop somebody from flying this design at the Red Bull Paper Airplane Contest in Austria (see 1:28 into the video):
http://www.youtube.com/watch?v=i5WzCuCFGNU
Step 1Folding the Surfer Paper Airplane
The surfer paper airplane is made from a standard 8 1/2" X 11" sheet of paper:
The nose assembly is used for many other paper airplane designs which differ from this paper airplane walkalong glider design only in how the fins are folded. The nose assembly is similar to the trapezium paper airplane design (proceedure is same up to 2:42):
The nose assembly and first fin fold is the same as before 1:09 in the following video:
The last fold on each wingtip is what distinguishes this glider from the rest. This fold starts at the front where the first fin fold intersects the leading edge of the wing. Then the edge of the fin is lined up with where the first fin fold instersects the trailing edge of the wing. This fold results in the outboard wingtip having a reduced angle of attack relative to the inboard wing, a design feature called wing washout.
52 comments
1-40 of 52next »
Jul 13, 2009. 4:30 PMDEADMAU5FTW says:
what was that thing in your hands?
May 28, 2012. 12:13 AMice45core0 says:
It looked a lot like glass or plastic.(In the kid's hands)
Nov 14, 2011. 12:01 PMfuture-tinker says:
cardboard to keep an air flow so that the plane can keep in the air for a long time.
Jun 20, 2010. 6:38 PMculepet says:
maybe it was a carboard,,,to control the wind,,powering up to the glider
May 19, 2010. 9:07 PMbob2 says:
 some string
Jan 25, 2012. 1:11 PMi love aircraft says:
there is no string
Oct 7, 2011. 4:32 AMshassan3 says:
i made it a million times but it just loops back and hits my head
Apr 3, 2011. 5:15 PMAir_Assassin says:
in your video, please go slower. Thanks!
Jun 17, 2011. 3:32 AMrainxsin says:
I think that because of the choice of a denser type of paper, the stability of the glider was in danger, so he had to move quickly. Perhaps if we switched the main material with one like the material used for newspapers/waxed tissue paper, it would be easier to control. Also, we notice that in this design the author has decided not to cut the tail wedge section..overall, it seems solid.
Jun 21, 2011. 8:13 PMAir_Assassin says:
what I really mean is the folding parts but thanks anyway :)
Sep 12, 2010. 8:20 AMwat. says:
WOW!!!!!!!!!!!!!!!!!!!!!!!!!! AMAZING!
Jun 26, 2010. 1:06 PMMR.SAINT235 says:
IT WORKS!!!!!!!
Jun 26, 2010. 1:01 PMMR.SAINT235 says:
I know how to make that!! All you need to do is know how to make the flat bed, then adjust the wings in that way!!!!
Apr 22, 2009. 2:00 PMPaperworker99 says:
is smaller cardboard work too?
Aug 21, 2009. 2:23 AMThe Jamalam says:
So, you could act as though you were using telekenesis? That would be so cool!
Mar 13, 2010. 3:03 PMcharleszxc says:
u guys r confusing  oh and hey jamalam
Jul 24, 2009. 7:41 PMcasey321b says:
do we just mess around with steering and flight or is there a video so i dont look stupid out in my driveway...
Jul 27, 2009. 7:51 AMStreet Soulja says:
cool.......................
Apr 21, 2009. 5:02 PMPaperworker99 says:
how could some body find a piece of cardboard that big!!!!
Apr 19, 2009. 8:35 PMowenebs says:
argh! when ever I throw mine it loops back to me upside down or just downright crashes into the ground! please someone help me!
Mar 19, 2009. 3:27 PMmacrumpton says:
If you made the glider out of wrapping tissue or condenser paper you would not have to run so fast. Also the wider the wing in proportion to it's length the more efficient it is (although beyond about 5 or 6:1 it runs into stability problems.
Aug 25, 2009. 9:13 PMjib451 says:
omg
Aug 26, 2009. 8:27 AMmacrumpton says:
It would be so cool if you could use a fan to blow against the cardboard to create an updraft that the glider could fly on without moving forward. When I was a kid in school we made these paper helicopters that you could hold over a radiator (they had these massive 10ft long radiators next to the windows) and the hot air rising would take the copters up to the ceiling and out into the middle of the room.
May 26, 2010. 8:43 PMShredder543 says:
Cool! if you can remember how to make them, plz post them!
Apr 15, 2009. 2:09 PMrogers236 says:
I've made a paper plane before with almost the exact same design, save the last few folds which were only slightly different. I found that if I made a hard crease for its fins and then flatten then back out. Then the fins will only pop up a little bit. This helps prevent the dips in the plane's flight and causes a much smoother flight without the need to fan it. Nice 'ible btw
Apr 15, 2009. 2:13 PMrogers236 says:
Forgive my error in syntax. lol
Correction: I found that if I made a hard crease on the fins and then flatten them back out, the fins will only pop up a little bit and this helps to prevent the dips in the plane's flight, causing a much smoother flight without the need to fan it.
Mar 20, 2009. 8:55 PMvitruvian8807 says:
Very cool. I once made a flapping paper airplane. Only if I had saved it, it'll take me weeks to try and recreate it if I ever attempt to. I've also made planes that come back to you almost always, though I suspect they're not that hard to make.
Mar 20, 2009. 9:02 AMpooter1433 says:
That was pretty cool. Hey you made the email distro and the homepage of Instructables. I don't think many of these other "experts" have. So good on you!
Mar 9, 2009. 10:33 PMAttackingHobo says:
Your design is tail heavy base on its glide performance. It keeps stalling, and going down, and stalling. Either add the weight to the nose, or remove some weight from the tail.
Mar 19, 2009. 10:59 AMdpocius says:
Alternatively, you could add lightness to the tail, or remove lightness from the nose. At least, that's how Colin Chapman (Lotus) would do it.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:walkalongaviation
