3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Paper Airplane Walkalong Glider
Step 4Powering and Controlling the Surfer Paper Airplane
A 96cm X 75cm piece of corrugated cardboard was used as a controllable slope. Larger area controllable slopes produce more relative headwind for the walkalong glider and not as much velocity is needed to sustain the surfer paper airplane (seeTumblewing Experiment: Paper mass Vs Ground Speed).
The surfer paper airplane is flown in a similar manner to other walkalong gliders. See the series of slides titled "Airflow Arond Controllable Slope", "Straight and Level Flight", "Climb" and "Turns" below.
Note the nose up trim which results in the up and down pitch oscillations of the surfer paper airplane when it is flying straight in the video (at 15 seconds into video). In the first turn, the plane stops the up and down oscillations because turns require more nose up trim (at 23 seconds into video):
Cutting off 0.75 inches from the trailing edge will lessen the phugoid oscillations when the paper airplane is flown straight and level. Alternatively, cutting off the trailling edge from each trailing edge to the base of the ballast will have the same effect (see indoor paper airplane walkalong glider instructable). Standard paper airplanes fly fast but not bad using large controllable slopes such as 75X100cm sheets of cardboard or foam core poster board.
7 comments
Apr 22, 2009. 2:00 PMPaperworker99 says:
is smaller cardboard work too?
Aug 21, 2009. 2:23 AMThe Jamalam says:
So, you could act as though you were using telekenesis? That would be so cool!
Mar 13, 2010. 3:03 PMcharleszxc says:
u guys r confusing  oh and hey jamalam
Apr 21, 2009. 5:02 PMPaperworker99 says:
how could some body find a piece of cardboard that big!!!!
Mar 10, 2009. 3:51 PMbrokengun says:
Nice! This reminds me of the paper planes that you can fly by holding your hand under them and walking.... they work on the updraft from your hands. Very cool and seems to work really well. Good work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:walkalongaviation
